King 3.0s Stock LCA’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totoya4x4, Apr 24, 2023.
  1. Apr 24, 2023 at 2:51 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I didn’t need to drill any holes to mount the remote reservoir for my 2.5s.
    I’m not sure why you repeated that you have a 3” lift, because it is my assumption that whatever you have is being replaced by the King coilovers.
    Totoya4x4[OP] likes this.
  2. Apr 24, 2023 at 3:10 PM
    Coldies
    Coldies Well-Known Member
    Travis
    San Diego
    2020 TRD Off-road 4x4 DCSB
    Just based off your comments I don’t think you’ll be using these shocks to there potential, a 3.0 is way overkill in the front for a non long traveled truck, why don’t you just stick with 2.5’s and see if King can make you a finned resi for the 2.5’s if they don’t already. Save some money for somewhat of the same look. If King or the companies selling the 3.0’s are selling them as a OEM shock then yes they should be a direct bolt in. Only problem I could see would be with the larger diameter spring coming into contact with your UCA especially if it’s heimed.
    Totoya4x4[OP] and gudujarlson like this.
  3. Apr 24, 2023 at 3:23 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You will not see a 3” lift from these unless you are adjusted way beyond the suggested length. These are marketed as a 1.5 - 2.5” lift and because these are listed with those heights and a Gen 2 - Gen 3 fitment I would expect these to be about a 1.5” lift on the front as they get about an inch lower lift compared to the second Gen trucks with the same suspension. If you want a 3” lift keep looking.
    gudujarlson likes this.
  4. Apr 24, 2023 at 3:27 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Agree. If you're doing this for looks OP, you do you. But you wont even come close to using their full potential. And as mentioned you will not have 3" of lift after installing these.
    But to directly answer your question, yes I *think* they will be compatible with standard Tacoma LCAs based on what I've read.
  5. Apr 24, 2023 at 3:41 PM
    Totoya4x4
    Totoya4x4 [OP] Member
    2022 Tacoma TRD Sport DCLB, 3.0 King Off-Road Racing Shocks, ICON AAL, Element UCA’s
    Thank you all, I’ll keep you guys updated.
  6. Apr 24, 2023 at 3:42 PM
    Totoya4x4
    I’m just stating I already have the lift I want, but from your statement below, adding these shocks will in fact lower my truck then?
  7. Apr 24, 2023 at 3:45 PM
    Totoya4x4
    What does heimed mean?
  8. Apr 24, 2023 at 3:46 PM
    gudujarlson
    Minnesota
    What type of lift do you have now? If it is a top-hat spacer, then technically you could combine it with your king coilovers, but it sounds super rinky-dink.
    If you have aftermarket coilovers, then no you cannot combine them with the king coil overs.
  9. Apr 24, 2023 at 3:52 PM
    Totoya4x4
    Hell no
    I did it correctly
    I went with the upgraded coilovers, I have the Elka 2.0s and they’re adjusted to 3 inches in the front (same as the rear) the 3 inches includes the stock ride height of the TRD Sport, so not 3 inches on top of the stock ride height but included
  10. Apr 24, 2023 at 3:54 PM
    SR-71A
    Zack
    Southern Maine
    So don't take this the wrong way, but it seems like you're very new at this. As I said before, if you have a specific vision in mind for how you want your truck to look - and if the King 3.0s get you there with the massive finned resi's and shock bodies, then do it up.
    But if you're looking for lift, or for performance, or anything else you should spend some time on here and on google looking stuff up. Theres a ton of questions when it comes to this stuff, and Id bet all of them have been answered at some point or another on here.
    To give you some perspective, I only know of a few folks on here that run these King 3.0s. So you are in somewhat unknown territory. If you are after a specific look or feel to your build you most likely will be able to find it for a much more attractive price going another route.
  11. Apr 24, 2023 at 3:58 PM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    Heimed is the joint of the upper control arm. Basically you have uniballs instead of the urethane bushing others have. They give you more adjustablitity.
    Regarding the 3.0s Do what you want, any shock replacement kit is just going to give you a max of 2.5 on any lift. Don't expect to go above that without doing more as your CV axles go to complete hell past 2.5 ins.
    The 3.0 shock kit from king will fit a stock Tacoma as a direct replacement, as that is how it is sold. Call KING up and they will tell you exactly what your asking.
    http://www.kingshocks.com/products/oem/toyota-oem/
    Its an OEM replacement so youre good to go.
    drizzoh likes this.
  12. Apr 24, 2023 at 4:03 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    FYI thats not doing it right...
    If you did it right you would have king, fox, ads, or icon and not be posting this question here. You also wouldn't think 3" is a good call.
    Read more, this forum is flooded with information.
    Only real advice I can give is research, research, research before you buy or youre just going to spend money left and right replacing stuff.
  13. Apr 24, 2023 at 7:21 PM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    SR-71A and Totoya4x4[QUOTED][OP] like this.
  14. Apr 24, 2023 at 8:05 PM
    Totoya4x4
    Whatever man, take your own advice and thanks
  15. Apr 24, 2023 at 8:05 PM
    #35
    Totoya4x4
    Ty sm
  16. Apr 24, 2023 at 8:46 PM
    #36
    MGMDesertTaco
  17. Apr 24, 2023 at 9:52 PM
    #37
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    All I want to know is why Elka does not count as a quality brand compared to others listed? Because that is one ignorant statement to suggest they are any less than what's listed.
  18. Apr 24, 2023 at 10:08 PM
    #38
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    lot's of cheddar for the look, but I am game, let us know how it goes!
    SR-71A likes this.
  19. Apr 24, 2023 at 10:21 PM
    #39
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Just because he didn't list it doesn't mean he's implying they are not a quality brand.
  20. Apr 25, 2023 at 5:12 AM
    #40
    Totoya4x4
    MGMDesertTaco[QUOTED] likes this.
