King Coil Over Making Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zachs_Tacomer, May 17, 2020.
  1. May 17, 2020 at 9:13 PM
    Zachs_Tacomer
    Zachs_Tacomer [OP] Well-Known Member
    Zach
    2017 TRD Off Road 4x4
    King Coils W/ adjustable reservoir, Icon UCA, Icon air bump stops, 16" Method NV, 285/75/16 Toyo AT2
    So i sprayed dry lube at the top towards where the top part bolts to the truck. Like right where the coil over assemble connects to the top mount. I was told there is a spherical up there.
    DocME[QUOTED] likes this.
  2. May 17, 2020 at 9:14 PM
    Zachs_Tacomer
    Zach
    I havent tried lubing the lower spherical. Dumb question, where is that?
  3. May 17, 2020 at 9:15 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Under normal spirited use, the rears would fail first due to pitting on the rods and failed shaft seals. Usually caused by throwing rocks from the front tires off road. I guess the OP could still have an issue with the shocks, but it doesn’t sound like what you’d expect. Especially because they look so good in the pictures. Hardly looks broken in yet. Good luck on finding your issue.
    12TRDTacoma likes this.
  4. May 17, 2020 at 9:16 PM
    DocME
    California
    '07 FJ Cruiser
    Other end of the shock where the bolt goes through. Although I’m not a huge fan of spraying tons of lube, as it will attract dust and grit causing premature wear. Usually keeping them clean is better than keeping them lubed.
  5. May 17, 2020 at 9:17 PM
    Zachs_Tacomer
    Zach
    Only thing i'll say to that is this pic was taken at 20K miles. I dont have a 50K mile pic. They still look clean and not beat tho
  6. May 17, 2020 at 9:17 PM
    Zachs_Tacomer
    Zach
    I hear you on that. Even if its dry Lube? I know exactly where you are talking about that
  7. May 17, 2020 at 9:21 PM
    DocME
    California
    '07 FJ Cruiser
    It’s probably ok, but I’ve had better luck just wiping them clean every once in a while. I will resort to lube if they act up, but that’s usually when I start thinking about ordering replacement bearings.
  8. May 17, 2020 at 9:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You don't live coilovers. Keep them dry, keep them clean and you're good to go the MAJORITY of the time.
  9. May 17, 2020 at 9:23 PM
    Zachs_Tacomer
    Zach
    Good to know. Thank you for that. What i was thinking is get some degreaser or some sort of cleaner and try and spray everything down. If that doesnt do that trick maybe dry lube / replace that spherical if thats the issue
  10. May 17, 2020 at 9:24 PM
    Zachs_Tacomer
    Zach
    Yeah i didnt lube the coil its self. Just the top spherical where the entire assembly goes into the top hat area that bolts to the truck
  11. May 17, 2020 at 9:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The lower is right where the shock mount with the large bolt is at. Spray in there.
  12. May 17, 2020 at 9:30 PM
    eon_blue
    Azusa, CA
    If it goes away when you wash the truck it's gotta be the spherical bearings in the lower eyelets. I had to replace mine after about 15k miles. They clunked any time I moved from a stop, could get it to go away for a few days by spraying dry lube on them.
    It's an easy job to do, but at 50k you should probably just get the entire coilovers rebuilt anyway
    Zachs_Tacomer[OP] likes this.
  13. May 18, 2020 at 9:55 AM
    eon_blue
    Azusa, CA
    The dry lube works well to quiet them down for a bit but you don't want to let bad bearings go for too long or they'll destroy the bottom of the shock by wallowing out the eyelets or worse. The eyelets are replaceable but it's easier and cheaper to just replace the bearings.
    DocME likes this.
