king coilover problems help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacosupreme, Jan 14, 2012.
  1. Jan 14, 2012 at 6:48 PM
    04tacosupreme
    04tacosupreme [OP] Member
    charlie
    hawaii
    04TRD v6 4x4
    alcan leaf pack, king shock coilovers, fabtech 6" drop bracket, total chaos upper a arms, gray wire, strait pipe, shit load of jimmy rigs
    howsit, well this actually might not be as bad as my title seems but i got an 04 taco with a fabtech 6, king coils cranked to i believe about 3"....has to be because im on my third set of cvs.....and also total chaos upper a's....any how my alignment is off and my tie rods and ball joints needs to be changed so as i was lookin at all that stuff underneath i noticed that my coils are hitting my cv axles...theres scuff marks on both...wtf??? any advice would be great...thanks.....also my truck makes a knock sound when i go over bumps.....
  2. Jan 14, 2012 at 8:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  3. Jan 14, 2012 at 8:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Your coils are hitting your cvs? How is that even possible?
  4. Jan 14, 2012 at 9:05 PM
    singlefin
    singlefin Well-Known Member
    Portland, OR
    Syncro
    Maybe he has some odd 2wd coilovers that don't clear the axles? :confused:
    Sounds like your truck is a mess bro. Take a few pics of the front suspension so people can help you sort it out.
  5. Jan 14, 2012 at 9:20 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    So it's at 9" lift?
  6. Jan 19, 2012 at 1:40 PM
    04tacosupreme
    charlie
    hawaii
    04TRD v6 4x4
    Lmk if these pics are good enuf......i think it mightbe hitting because of all my loose joints underneath but not sure.....as far as my "tock" sound ......im thinkin either lower a arm bushings, ti rods, orball joints...... my next move will be to strap my go pro underneath andsee if i can spot sumthin unusuall..... or hell just replace the whole underneath....... also anyone knows of good brand of sprays fr undercoating???? Mahalos in advace :)
  7. Jan 19, 2012 at 1:42 PM
    04tacosupreme
    charlie
    hawaii
    04TRD v6 4x4
    Bout 9" i think...... dont think i have a true 3" lift off them coils cos my trck sits lower than other tacos wit a true 9 so idk but my cvs go quite often...
  8. Jan 19, 2012 at 1:44 PM
    04tacosupreme
    charlie
    hawaii
    04TRD v6 4x4
    Dnt know if it is bro but sumthins goin on underneath that i cant figure out and its friggen annoying. Lol.
  9. Jan 19, 2012 at 1:45 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    the knock going over bumps could be the axle hitting the coilover while compressed
