King coilovers adjustable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Aug 23, 2010.
  1. Aug 23, 2010 at 9:43 PM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I have a pair of King coilovers sitting in my garage (OEM set I believe) and I am wondering if/how they are adjustable...
    I know it may be a dumb question but I haven't taken a close look at them and am wondering if anybody just knows the answer.
    Thanks
  2. Aug 23, 2010 at 9:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    yes they are. You turn the large retaining nut on the threads to lengthen and shorten the spring.
  3. Aug 24, 2010 at 6:44 AM
    RattleTractor
    Harry
    VT
    Do you mean the small allen wrench nut in the disc at the top of the spring?
  4. Aug 24, 2010 at 7:28 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    that disc, or retaining nut, is the thing that you turn. it should be on threads. and the allen screww just locks the nut inplace. so you have to loosen that screw first.
  5. Aug 24, 2010 at 7:39 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    and why are they sitting in your garage and not on your truck? :D
  6. Aug 24, 2010 at 4:02 PM
    RattleTractor
    Harry
    VT
    Ha because I took them off for OME. Then I didn't feel like putting them back on. Now I want them back on and I want them set at 2.5".
    Can you adjust them while they're on the truck?
  7. Aug 24, 2010 at 4:15 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    ^ yes, you can adjust them while they are on the truck but the UCA tends to get in the way and you might have to unbolt it from the spindle to get the needed room to turn the top collar.
    when you adjust them on the truck be sure to have the truck jacked up and the susp fully drooped so there is no weight on the shock. loosen the set screw, crank away and the retighten the set screw and lower the truck down. if you like cool, if not repeat the previous steps
