King Coilovers
Discussion in 'Suspension' started by PhilipRoth, Jul 13, 2010.
  1. Jul 13, 2010 at 1:12 PM
    PhilipRoth
    PhilipRoth [OP] Well-Known Member
    Az
    06 Tacoma
    King shocks!
    About 2 weeks ago installed kings front and back with TC UCA's from downsouthmotorsports. I would like the front to sit up a little higher to be level but dont want to lose ride quality. I have a 4x4 so what are my options? :eek: Anything would help
  2. Jul 13, 2010 at 1:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I know on my fox's I could swap my springs out for longer ones. Not sure about the kings
  3. Jul 13, 2010 at 1:36 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Maybe that'd work. Anyone else?
  4. Jul 13, 2010 at 5:29 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    You would have to get longer springs if you don't want to preload them at all. Only option with a 4x4. Or a drop bracket lift
  5. Jul 13, 2010 at 5:29 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    crank down the sping on the CO's a bit farther... or are your cv's as far as they shoulg go?
  6. Jul 13, 2010 at 6:27 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    He is right. You can add more preload to the coilovers but you need to make sure your CV boot fins dont touch. If they do they will wear out very quickly. The ride will get a bit stiffer too as you crank them higher. Try it out cranked a bit and see how you like it.
    You can go to a stiffer spring for more height but the shock wont work as well unless you have a heavy front bumper to justify the stiffer spring. Its a constant battle getting the height and ride dialed in. Mine still needs some work.:(
  7. Jul 13, 2010 at 6:32 PM
    cummins6speed
    You can get longer springs with the same or lesser spring rate if you wanted
  8. Jul 13, 2010 at 6:34 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Try preloading them to give it another inch of ride height or where you want it, you can always bring them down if its too harsh.
  9. Jul 14, 2010 at 1:33 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    had same problem i crank them up blew both cv's they didnt even look like they were touching. and the ride was very stiff. learned my lesson after to cv lowered them and wayyy happy with the smooth ride over the hight
  10. Jul 14, 2010 at 6:59 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    you can also run a 750# spring vs the 650# spring you are most likely running now. I have 750's on mine and the collar is all the way up for that caddy ride.
  11. May 20, 2017 at 11:03 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Ive been getting a bit of conflicting info on this. Anybody who knows there stuff wanna chime in? Doesnt a longer spring, lets say 14" from an original 13" coil, have the same amount of preload if the vehicle is at the same ride height ? The collar is set up an inch or so (less visible thread) but physically it is the same amount of preload/ stiffnes
  12. May 20, 2017 at 11:06 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This thread is 7 years old... just a heads up
  13. May 20, 2017 at 11:32 PM
    Suicyco
    14 ac 4x4
    Ya well whats the alternative get bitched at for starting a new one or bitched at for reviving an old one. I tossed a coin
  14. May 20, 2017 at 11:39 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Start a new thread, people bitch. Actually used the search mode and bumped and old thread? Bitch... :laughing:
    the info is still relevant tho.
    Justinlhc and Suicyco like this.
  15. May 21, 2017 at 9:14 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    http://www.worksperformance.com/html/tpl_desc.html
    Correct. I think a lot of people just get confused when they're talking about it.
    Suicyco[QUOTED] likes this.
  16. May 21, 2017 at 10:31 PM
    Suicyco
    14 ac 4x4
    @Justinlhc if the springs are linear, same spring rate regardless of preload, than why do the coilovers seem stiffer with more preload. Thts whats confusing me
  17. May 22, 2017 at 5:53 AM
    Justinlhc
    I wish I knew because I experienced the same thing, but people smarter than me say it doesn't change :cookiemonster:
  18. May 22, 2017 at 5:57 AM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I just added peload to.mine but plan on upgrading my springs soon. But adding a diffrenet spring it also stiffns the ride
    Suicyco likes this.
  19. May 22, 2017 at 7:06 AM
    SocalOC
    2015 Sport
    Im going 700 since im getting a bumper here soon plus the skids
  20. May 22, 2017 at 10:16 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    You lifted it high enough that the rough ride is the lack of droop travel. You want to be about 3" of droop from ride height.
