King coilovers
Discussion in 'Suspension' started by J.Maynard, Feb 26, 2015.
  1. Feb 26, 2015 at 11:11 PM
    J.Maynard
    J.Maynard [OP] Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    I found some nice King coilover for a good price on craigslist but there for a 2000-2006 tundra. Does anyone know if these will fit my 2001 tacoma. From what i compared on offroadshocks.com between tundra and tacoma they seem to have the same dimension. Any input would be great thanks!
  2. Feb 26, 2015 at 11:18 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    They may have the same length but I know the rod end, hose routing and spring are different. I'm not sure about the upper mount bolt pattern but that could be different also. Send me a PM to remind me and ill find that out for you. Even with the different rod end and hose routing you could still make it work without a problem because the hose routing can be adjusted. The rod end shouldn't effect it but it may have some clearance with the sway bar, front axles, UCA, etc..
