King extended coilover
Discussion in 'Suspension' started by DiffLock, Oct 3, 2017.
  1. Oct 4, 2017 at 5:07 PM
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Thanks I was wondering about that. I am not sure how much to adjust it.
    Tacomamike mike likes this.
  2. Oct 4, 2017 at 5:10 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Its the reserviors that get in the way. The tc uppers don't change anything
  3. Oct 4, 2017 at 5:16 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Does anyone know how many threads of preload I need for 2.5” lift?
  4. Oct 4, 2017 at 6:23 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Depends on your weight and setup
  5. Oct 4, 2017 at 6:24 PM
    eon_blue
    eon_blue Most Improved Member
    I think I had to turn mine 8 times to gain an inch, but yours may be different.
    Edit: 8 full rotations of the collar. Takes forever and is near if not impossible with the UCA in the way.
  6. Oct 5, 2017 at 8:58 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    guys I've got a problem. when I turn the adjusting collar, its turning the shock body, so I am not gaining any threads. it is held firmly at the bottom. collar allen is loosened.
  7. Oct 5, 2017 at 9:25 AM
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    You have to hold the body side. The rod will just spin as you've discovered.
  8. Oct 5, 2017 at 11:01 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    thanks
  9. Oct 5, 2017 at 4:43 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I don't have a good vise, so I came up with this. mounted the shock to a board. with a little triflow on the threads it worked great! 1.25" / 11 threads on the left (to compensate for lean) and 1" / 9 threads on the right. If the lift is too much once I install them, it will be much easier to move it lower versus higher.
    JoeCOVA and Tacomamike mike like this.
  10. Oct 5, 2017 at 4:49 PM
    eon_blue
    haha, someone in the Wheelers Anonymous thread just yesterday morning was telling me that they did the same exact thing to adjust their's. I'll probably end up having to do the same when I take mine off soon to readjust the preload.
  11. Oct 6, 2017 at 4:00 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    got it done today. ride height is now 24" (3" over stock). rides great and almost level too... very happy.
  12. Oct 6, 2017 at 4:21 PM
    eon_blue
    Nice! So how many full turns of the collar to get the height you wanted?
  13. Oct 6, 2017 at 4:31 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Ten threads. Not sure how many turns.
  14. Oct 6, 2017 at 4:35 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Freaking great thread !!! Great insight into the King coilovers and mounting !
    BigHoss96 and DiffLock[OP] like this.
  15. Oct 22, 2017 at 11:30 PM
    #35
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    So youre showing 10 threads above the collar? I need to go and count mine. My truck doesn't look like its on a 3" lift compared to everyone elses rig
  16. Oct 22, 2017 at 11:47 PM
    #36
    eon_blue
    Just for future reference, you can adjust Kings with them on the truck if you remove the bottom bolt but leave the top bolts in. Pull the bottom of the shock toward you and this allows you to move the UCA out of the way with a jack under the LCA (crank it up until it clears). The shock stays in place via the top bolts still attached and its much easier to adjust with the UCA jacked up and out of the way. Did mine this way a couple weeks ago, worked well.
  17. Oct 23, 2017 at 7:17 AM
    #37
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Yes. Measure from fender to hub center to check your height.
    4x4Taco09[QUOTED] likes this.
  18. Jul 17, 2018 at 8:53 AM
    #38
    fasback428shelby
    fasback428shelby Well-Known Member
    john
    lawndale,ca
    tacoma baja
    How many threads are you showing ?
  19. Oct 15, 2018 at 1:04 PM
    #39
    cookler997
    cookler997 New Member
    mike
    2017 tacoma trd 4x4
    Now remove the sway bar.. it will make off-road much better. just be careful on the streets
