king oem 2.5 rear
Discussion in 'Downsouth Motorsports' started by deog, Oct 2, 2013.
  1. Oct 2, 2013 at 7:05 PM
    deog
    deog [OP] Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Is the king 2.5 rear oem replacement a 10" travel shock ?
    If paired with a j59 deaver leaf pack does the axle need to be limited by being strapped ?
    what is the perfect shock setup for a j59 leaf pack with factory height shackles ?
    what kind of travel numbers can be expected with the king oem replacement pack and j59 pack
    thanks in advance for replies.
  2. Oct 3, 2013 at 8:11 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    No it is not a 10, it is closer to a 8".
    You always want to run a limit strap, you would never want the shock to limit the suspension travel.
    You would need to provide me with extended and collapsed numbers, every set up is going to be different between shackles, mounts, straps, bumps, ect..
    If you can get me numbers, we could build a shock that will work best for your application.
    Micah
