King shock question..
Discussion in 'Long Travel Suspension' started by BMiller421, Sep 29, 2011.
  1. Sep 29, 2011 at 11:27 AM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
  2. Sep 29, 2011 at 11:32 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I dont think there is enough room. I would email or call King
  3. Sep 29, 2011 at 11:33 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i would think cause 8inch coilovers are too short to have 2 different spring rates.
  4. Sep 29, 2011 at 11:45 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Like everyone said they are a little too short. you can still do it but its know to really lower the truck and it doesn't make enough difference to do it. I asked last time I was at Kartek
  5. Sep 29, 2011 at 12:29 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I'm curious to my truck sits way to high.
  6. Sep 29, 2011 at 12:34 PM
    amaes
    Alex
    Chandler, AZ
    2011 FJ Built
    Its the geometry of the engage kit. The way everything is setup on those kits they sit sky high. Look at your uniball angle on their kit. Its almost maxed out at ride hight on all of the stuff I have seen in person.
  7. Sep 29, 2011 at 7:52 PM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    Chris arent you running a 4 inch "race" spindle. my truck doesnt sit that high. i have a stock gusseted. Also what tire size r you running. Im running 35's.. i have about an inch of pre load turned into the front..
  8. Sep 29, 2011 at 8:03 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    It should work, and the guy on DR isnt gonna switch coils?
  9. Sep 30, 2011 at 8:52 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    why? is it just to blow money down the drain?
    just get a softer spring rate and be done with it.
    first off i dont think you can get the collar on the shock to tune the seconday spring engagement zone. then theres very little room to set the collar up properly . then the probably 3-400$ to buy 2 sets of springs and rate plates. then because of the short springs and rate plate the coils are so short you may put them in coil bind
    now you could remove all the preload to get your rideheight and them the spring will most likely be loose at full droop . at that point you could play around with a spring tender to take up the slack . but the added spring will probably bring the ride height up a little bit depending on space constraints
    just bring it by my shop and we will get you figured out.
  10. Sep 30, 2011 at 10:24 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Where is your shop?
  11. Sep 30, 2011 at 10:27 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    He said it is too far to meet up halfway..and he doesn't want to borrow a car..
    But whatever..
  12. Sep 30, 2011 at 10:45 AM
    Defined
    mike
    southern california
    ah, sorry i just saw you were in bakersfield.
    im in yorba linda, ca near anaheim
  13. Sep 30, 2011 at 11:31 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Hmm..maybe i'll take the wife and kids to disneyland one of these weekends..then stop by..
    I think in the meantime..i'll just buy some softer eibach springs and give them a shot since my idea is frowned upon..
