King shocks offroad squeak
Discussion in 'Suspension' started by C4S7R0, Sep 18, 2016.
  1. Jul 25, 2024 at 5:24 PM
    jameschowell
    jameschowell Active Member
    James
    2019 Toyota Tacoma 4x4 TRD Off Road
    Just ran into this same issue. Poly bushings not the issue but it is indeed the lower rod end bearing on my driver side shock. Ordered a new set for both sides from 303 shock.
    When in doubt, break the stethoscope out
    TMFF likes this.
  2. Jul 26, 2024 at 7:11 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Replace the lower shock bolts with ones from a 4runner and those lower mount bearings will last a little longer. 4runner's ones have a shaft that is the same diameter all the way through. Tacoma ones taper down halfway across and then it doesn't make good contact with the bearings.
    jameschowell[QUOTED] likes this.
  3. Jul 26, 2024 at 7:52 AM
    jameschowell
    James
    Good call, I bought those from 303 as well.
