King Spring Predicament Part 2 (600/650/700)
Discussion in 'Suspension' started by LastoftheGen2, Mar 31, 2022.
  1. Apr 6, 2022 at 11:49 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If the risk is acceptable to you that’s fine with me. What I was trying to say is that you haven’t really tested the new setup to determine there is no difference. It’s like removing your air bags, driving down the street, and then declaring there is no effect. You have to actually put the truck into a situation where the anti roll bar is fulfilling its purpose.
    BattleKat likes this.
  2. Apr 6, 2022 at 5:32 PM
    LastoftheGen2
    LastoftheGen2 [OP] Well-Known Member
    Mighty Mo
    NY & Vermont
    2015 Taco TRD Off Road
    Fab 4 Bumper with 9,000LB Winch. Prefy high lift rear bumper, All-Pro rock sliders, steel skids, expedition leaf pack and U-Bolt flip kit, King shocks with 700 lb springs, BFG AT KO2's 265/75, Safari snorkel, rear diff breather mod.
    How about the dissconnectable sway bar links. Are they any good. Most of them seem to be put together with small Cotter pins that don’t really seem substantial enough to hold the sway bar under on road driving
  3. Apr 29, 2022 at 7:28 AM
    jhmw815
    jhmw815 Well-Known Member
    Los Angeles, CA
    2018 Tacoma Trd Pro
    650lb :thumbsup:
    I'm rocking 650lb w/ steel bumper, winch, upgraded battery, rock slider, full armor (aluminum) roof rack, bed rack, rtt, and it's perfecto!
    kirros40 likes this.
  4. May 6, 2022 at 7:40 AM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    OP what did you do and how did it end up?
  5. May 6, 2022 at 7:45 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Check out t8nkers adventure on YouTube to better understand toyota IFS
  6. Jun 20, 2022 at 1:17 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    They have not been created for the Tacoma. Would be nice if someone could figure it out. Doesn't seem like there is a method to tuck them away when disconnected...
  7. Jun 20, 2022 at 6:36 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    That is not correct
    https://www.tacomaworld.com/threads/3rd-gen-sway-bar-quick-disconnects.471919/page-2#post-26212891
  8. Jun 21, 2022 at 8:23 AM
    findingthingsout
    midwest
  9. Jan 7, 2024 at 12:17 PM
    kirros40
    kirros40 2017 TRD OFF-ROAD DBL CAB 4x4
    San Diego,CA
    What lift height did you go with? Thanks
  10. Nov 20, 2024 at 3:34 PM
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    how many threads down are you on the coils and what’s your center to fender measurements. Mines weird…
    21.5 and I’ve got 13 threads showing.
  11. Nov 20, 2024 at 7:04 PM
    WEW
    WEW Member
    San Diego, CA
    General rule for the chassis is 80-140 pounds of additional front end weight will use 650 lb/in springs and 150+ will warrant 700 lb/in springs.
    If you are swapping from 600 to 700 lb springs you need to revalve the shocks, honestly you should do it for 650s as well. 14" 700s will take 550 lbs more force to fully compress vs 600s, its a big difference. Kings standard Tacoma valving will have all 3 bleed holes in the piston open which will be quite jittery for your application.
    Mt133677 likes this.
  12. Nov 27, 2024 at 3:29 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I recently went form 600 to 700 pound springs. My front end is heavy bumper, heavy winch, big steel skid, tundra rack, GRP 31 AGM, she's heavy up front.
    With the 600s, I had been noticing a little sag upfront to where I had to adjust preload to even it out a little. It got worse after the battery. I have not had a sway bar in years. With the 600s on a fast turn the body roll is enough to frighten passengers that are not ready for it. I like it because it was super loose off road, my shocks are adjustable so you have some room to play, and the sumo springs just soak it up.
    With the 700s, I was able to remove almost an inch of preload and maintain the same height. Body roll is similar, just a tad less. I have zero issues with harshness, zero issues with drivability. The only difference I notice drivability wise, is a little less body roll, everything else feels the same. She drives like dream I have zero harshness when I'm driving fast or slow.
    It's difficult to only focus on real world spring rate differences in standard applications as there is so much more going on with our vehicles. All of us have different lifts, wheels, tires, bumpers skids, the weights are going to be different. And then you take into account how all of us drive differently. We will all experience different spring rates differently.
