King suspension/parts via Mocha Performance *UPDATED*
Discussion in 'Automotive Group Buys' started by Gary86, Feb 19, 2019.
  1. Mar 24, 2019 at 4:13 PM
    #381
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @raskal311 it allows you to adjust how soft or firm the shock will react to compression/extension
    raskal311[QUOTED] likes this.
  2. Mar 24, 2019 at 5:15 PM
    #382
    Rowan11b
    Rowan11b Well-Known Member
    2017 dcsb trd or
    PSA: you do not need extended rear shocks to run with you RXT packs. The travel gains icon gets with that pack is primarily from the offset eyelet allowing more compression, not droop. If you run a longer rear shock without properly setting up your bumps, brake lines, etc you will more than likely stretch your lines or blow your shocks on compression IF your springs actually allow for the additional travel.
  3. Mar 24, 2019 at 5:18 PM
    #383
    Rowan11b
    2017 dcsb trd or
    I run bilstein 8100s with rxts on setting 3, the bilstein 8100 is a shorter shock than the standard kings, the shock is a hair longer than the springs at max droop.
  4. Mar 24, 2019 at 6:31 PM
    #384
    cratagus
    cratagus Well-Known Member
    coquitlam BC
    2017 double cab TRD
    speaker upgrade, toytec lift SCS wheels ( ray 10), magnaflow exhaust, 285 BFG Ko2
    interested in joining group buy.
    2.5 extended with resi and adjuster - 700 lb for front
    will send you a PM.
    Gary86[OP] likes this.
  5. Mar 24, 2019 at 7:27 PM
    #385
    Rowan11b
    2017 dcsb trd or
    Interested parties please PM me and I will respond asap
  6. Mar 24, 2019 at 8:12 PM
    #386
    Gary86
    Gary86 [OP] IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    I’ve responded to all the “interested” and forwarded your email to two who were onboard.
  7. Mar 24, 2019 at 8:51 PM
    #387
    Rowan11b
    2017 dcsb trd or
    At this point if people want extended rears, screw it I'll make it happen, jeeze some of yall are worse than my wife
    solrchrgd likes this.
  8. Mar 24, 2019 at 8:58 PM
    #388
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I believe it.
    I think people are more of the symmetry of ext front and rear vs ext front standard rear.in all complete honesty I could only find very little on the subject. Even brought it up on here. I did see your post with the rxt lead pack and it makes sense. I'd have gone the bilstein route but the MAP came down and I wasnt paying attention before hand.
  9. Mar 24, 2019 at 11:13 PM
    #389
    trd_kevin
    trd_kevin Well-Known Member
    Kevin
    2017 White Tacoma TRD 4x4
    Too much
    Curious what springs King uses for their coil overs?
  10. Mar 24, 2019 at 11:37 PM
    #390
    Rowan11b
    2017 dcsb trd or
    On the tacoma 2.5 coilovers they are 14x3 600lb standard, but they can be ordered with different spring rates.
  11. Mar 25, 2019 at 7:11 AM
    #391
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    What’s the details on the kit? I’m pure stock and fairly noobish to lifts. Possibly interested.
  12. Mar 25, 2019 at 10:09 PM
    #392
    Ryandoobs
    Ryandoobs Active Member
    Dallas
    Prerunner
    Interested
  13. Mar 25, 2019 at 11:15 PM
    #393
    cgaulzetti
    cgaulzetti Member
    Craig
    Soon...
    i've got a stock 2wd 2017 TRD Sport and am interested. Let me know!
  14. Mar 26, 2019 at 5:10 AM
    #394
    BlacknBlue2002
    BlacknBlue2002 Well-Known Member
    Va Beach
    16 DCSB TRD O/R
    Bilstein 8100's (2.5" lift), SPC LR UCA's, 315/75r16 Hankook DynaPro MT's, SCS F5's (3.5" BS), Leer XQ shell
    Interested - please PM price
  15. Mar 26, 2019 at 11:00 AM
    #395
    silvrtaco
    silvrtaco Well-Known Member
    Interested. please DM pricing
  16. Mar 26, 2019 at 6:09 PM
    #396
    Addicted2Pomade
    Addicted2Pomade Well-Known Member
    Eddie
    Socal
    2010 Super White Tacoma Long travel
    Interested.
    2.5" Extended Travel w/ Compression Adjusters and 600lb coils
  17. Mar 26, 2019 at 7:59 PM
    #397
    B1sko3
    B1sko3 Cali Raised - Military Driven ⚓️
    Nabiskoe
    LA, California
    2019 Cement
    Interested... Thanks
  18. Mar 27, 2019 at 7:41 AM
    #398
    Vizion
    Vizion Active Member
    Scott
    16' tacoma 4x4
    Interested, what other info do you need?
  19. Mar 27, 2019 at 7:51 AM
    #399
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    is it more than 25% off?
  20. Mar 27, 2019 at 8:24 AM
    #400
    xsf18cdf
    xsf18cdf Well-Known Member
    Gary
    Texas
    2019 TRD/OR/DC/LB/QS
    None
    about 10% off the best internet price you'll find.
    G
