King Suspension Question
Discussion in 'Suspension' started by TacoTyusday, Jul 23, 2020.
  1. Jul 23, 2020 at 2:56 PM
    TacoTyusday
    TacoTyusday [OP] Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I know I know, search the forums before posting. I did, couldn't find much, and I'm pretty sure this isn't a regularly asked question
    I ordered F/R Kings 2.5 with comp adjusters, the shop has been waiting on my rears to arrive for a while, but said that they have another set of the rear shocks with comp adjusters available, that have a 1" longer rod end and that I could take those ones if I didn't want to wait any longer.
    How they described it was that the one with the longer rod end is more of a "true" extended shock, while the ones I ordered are supposedly the same shock with an internal spacer removed to achieve the extra length?
    Not too savvy with suspension stuff, so would love if someone could help explain it to me better, and tell me why I should/shouldn't take em, and what kind of difference it would make for my suspension travel in the rear.
  2. Jul 23, 2020 at 2:59 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    If you are lifting the rear this sounds like a good option
  3. Jul 23, 2020 at 3:00 PM
    TacoTyusday
    Zac
    San Diego
    yeah that's how they described it to me. Basically, because my initial order was just an AAL, they went with the "standard" shock with the spacer removed for extended travel. Since I changed my order to an RXT pack, they said these would be better to go along with the lift.
    My question is, if the rod end is 1" longer, would that not reduce travel distance by 1"? Or is it just tacking on an extra 1" to the end without affecting travel?
  4. Jul 23, 2020 at 3:03 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Ask them what the compressed and extended lengths are for both shocks
  5. Jul 23, 2020 at 3:05 PM
    TacoTyusday
    Zac
    San Diego
    according to them, the same as the standard extended version. from their description, it's the exact same shock, just built with a 1" longer rod end and that supposed internal spacer removed
  6. Jul 23, 2020 at 3:06 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Should be good then. Same shock, more travel (more up travel which is great if you are lifted)
  7. Jul 23, 2020 at 3:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  8. Jul 23, 2020 at 3:08 PM
    TacoTyusday
    Zac
    San Diego
    perfect, thanks. trucks in the shop so wanted to get it all installed at once, and i can go today/tomorrow to pick up what they have vs waiting an indefinite amount of time for the rears that were initially on order.
    yup same shop haha. just wanted to get more user opinions, she told me the same and that this is pretty new to the market.
