King Suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kirros40, Jun 12, 2024.
  1. Jun 12, 2024 at 4:44 PM
    kirros40
    kirros40 [OP] 2017 TRD OFF-ROAD DBL CAB 4x4
    San Diego,CA
    Question. I finally got around to installing my
    25001-119-EXT and 25001-121, with 650lb springs. Camburg UCA, Deaver Expedition Stage 1
    I only have a C4 hybrid front bumper approx. weight 115lbs.
    After 2000 miles
    Is there anything I can adjust?
    Speed bumps cause the front end to be bouncy for a few seconds until it settles, and also front end excessively jumpy on on slightly uneven freeway sections Other than those scenarios it’s fine.
    Have lift height set at 2”, running 295/70/17 Mickey Thompson AT’s
    Thanks!!
    71tattooguy likes this.
  2. Jun 12, 2024 at 5:05 PM
    Gdeyarmond
    Gdeyarmond Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    When you say "bouncy" are they stiff? Or are they riding like a Cadillac bouncy?
    Stiff bouncy would be from too much preload (more than likely). Cadillac bouncy is probably from the valving and the spring combo. You need them revalved if it's really really squishy up front.
  3. Jun 12, 2024 at 5:42 PM
    kirros40
    San Diego,CA
    They are bouncy, not soft.
    The small bumps on freeway cause front end to be “jumpy” up front. It even resonates into cab, until it settles down.
    When the suspension was initially was installed it was fine. Not sure if it’s after springs settled or?
  4. Jun 12, 2024 at 5:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Tire pressures matter too. Make sure you're not overinflated.
  5. Jun 12, 2024 at 5:45 PM
    Gdeyarmond
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    Is that spring one that King recommends? King's are known for being too soft on road. I'm guessing that it's either too heavy of a spring, or there is too much lift (preload) and it is causing them to ride like that.
    Did you have it aligned after the install? If the steering is jumpy at highway speed, that probably means your alignment's caster is too high...the tire pressure could come into play as mentioned.
  6. Jun 12, 2024 at 6:01 PM
    kirros40
    San Diego,CA
    Thank you, I’ll check tire pressure.
    Appreciate it.
  7. Jun 12, 2024 at 6:04 PM
    kirros40
    San Diego,CA
    I spoke with King, and they mentioned to try them out first, didn’t recommend a specific spring.
    it was aligned after install. I did have tires rotated and re-balanced. Seems like ride got a bit worse, and the tires went out of balance fairly quick.
    Not sure if maybe another alignment is needed.
    I’ve been thinking about the tire pressure as.
    I appreciate all the feedback.
  8. Jun 12, 2024 at 6:10 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    What size spring do you have?
  9. Jun 12, 2024 at 6:18 PM
    kirros40
    San Diego,CA
    KST-25001-119-EXT-650lb
    14”
  10. Jun 13, 2024 at 4:45 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Bouncy for a few seconds sounds like you lost all damping. Do you have any fluid leaking from the shock?
    71tattooguy and AmateurTaco1313 like this.
  11. Jun 13, 2024 at 7:50 AM
    clg
    clg Well-Known Member
    2017 Off-road
    Preload and 650lb spring = bounce. Get them valved for the spring you've installed, or reduce preload on the spring which will in turn settle things down.
    The inclination to increase spring rates AND preload to maintain an aesthetic in the front end (lift) has consequences which make the vehicle behave poorly. Let's also be realistic, upgrading to a King coilover designed for off-road performance isn't going to be as comfy on the road as OEM. It's meant to absorb significant off-road use that would be beyond the limits of a stock suspension, that also comes with consequences.
  12. Jun 13, 2024 at 8:02 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Just as a point of reference / comparison, I have an ARB front bumper (no winch) and FOX 2.5 PE's w/ DSC + 650-lb spring-rate coils on front, + FOX 2.5 DSC & Deaver U402 stage IIIs, on rear. All provided by/tuned by Accutune, did the on-truck installation myself. Very nice ride under all conditions, with damping that is "as good as it gets." Can hit a large speed bump (i.e. on city / surface streets) at 30 mph fully loaded and the truck doesn't bounce at all. One dip & full recovery on the first rebound. My setup increased lift both front & rear by about 2", and that's with near-minimum preload on the front. Yokohama Geolandar AT tires in a standard size, usually at about 32 PSI.
    Not sure why this / your King setup isn't working correctly, might be shock valving or improper installation. Just saying that it's possible to get a good ride on-road w/ heavy duty aftermarket shocks/coils, at least if they have a wide range of adjustability as the FOX w/ DSCs do.
  13. Jun 13, 2024 at 8:14 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I’m running 700lb with steel bumper , winch all steel skids , sliders etc. 1000 pounds over stock. What’s your top hat to center bolt measurement? What was measurement of spring install on shock before install. My rig recovers like others have said one dip and recovers. Speed bumps at 20 no problem. E rated tires will change ride quality IMO. I also had my shocks tuned @AccuTune Offroad for weight etc.
    Good luck
  14. Jun 13, 2024 at 10:22 AM
    kirros40
    San Diego,CA
    Thank you appreciate it. They do well on the large dips. But it’s seems just on uneven freeway.
    I’ll look into possibly Tune as well.
  15. Jun 13, 2024 at 10:24 AM
    kirros40
    San Diego,CA
    Thank for reply.
    Yeah I think it might be the lack of tuning, and lack of weight up front for the 650lb springs.
    71tattooguy[QUOTED] likes this.
  16. Jun 13, 2024 at 10:26 AM
    kirros40
    San Diego,CA
    Thank you for reply.
    I’m trying pinpoint the issue. Seems like ride got worse after tire rotation and balance.
    The tire are going out of balance fairly quickly.
  17. Jun 13, 2024 at 10:27 AM
    kirros40
    San Diego,CA
    Any shops in San Diego that would be recommended to take in and inspect?
    Thanks everybody
  18. Jun 13, 2024 at 10:38 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Yes Accutune right in SD @AccuTune Offroad
    AccuTune Offroad and GilbertOz like this.
  19. Jun 13, 2024 at 10:41 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Do you plan on getting a winch?
  20. Jun 13, 2024 at 11:14 AM
    kirros40
    San Diego,CA
    Yes, hopefully .
