king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Feb 1, 2014 at 4:13 AM
    #281
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    Our standard coil rate is 650lbs, but for set ups as you described we offer a 700lb coil option. This will hold up the added weight over stock without issue.
    ICON is a great choice! :)
  2. Feb 2, 2014 at 12:41 PM
    #282
    4bangeronabudget
    4bangeronabudget Well-Known Member
    Maine
    08 2.7l base
    Blacked out badges Tough country lift Scs stealth 6 wheels LEDs Warn transformer w/ light bar winch mount Volant ram air intake Reese hitch Timbrens 5100s Warn 9500 winch Skids
    Do I need to call and ask for the heavier coil or is there an option somewhere that I have missed?
  3. Feb 2, 2014 at 12:42 PM
    #283
    icon_rep
    Riverside, CA
    Just let the dealer you are purchasing through know upon ordering.
  4. Feb 3, 2014 at 2:50 PM
    #284
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Can the Icon extended travels work with LR UCAs?
  5. Feb 3, 2014 at 2:54 PM
    #285
    icon_rep
    Riverside, CA
    As far as we know there is not an issue, might want to double check that with a few others. Maybe some people will chime in to confirm.
  6. Feb 3, 2014 at 2:59 PM
    #286
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    I run ext icons with LR ucas and it's been flawless
  7. Feb 3, 2014 at 4:13 PM
    #287
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Yep
    Clears them no problem and has more then enough travel with them.
    Totally happy with mine
  8. Feb 3, 2014 at 6:12 PM
    #288
    TacoBrah
    Sean
    How many miles typically before a rebuild is necessary on the icons?
  9. Feb 3, 2014 at 6:19 PM
    #289
    icon_rep
    Riverside, CA
    Recommended is 30-40k. Beyond that you need to factor in things like heavy offroad use often, use in extreme conditions hot / cold which may require this number to be lowered. Obviously this is your choice, but that is what we recommend to keep them in good work condition with no loss in performance from wear.
  10. Feb 3, 2014 at 8:48 PM
    #290
    TacoBrah
    Sean
    How much is the rebuild kit and how much labor is typically involved?
    Any major differences between Camburg and LR UCAs? I see they are both priced similarly.
  11. Feb 4, 2014 at 9:29 PM
    #291
    icon_rep
    Riverside, CA
    Rebuild kits are 36.00 each and oil for a pair of shocks is about 35.00. Labor is about 30-60 minutes each depending condition, and if there is a spring being pulled on and off. (sometimes people send them in without them on)
    As far as the arms I can not help you there, I can only speak on ours.
  12. Feb 5, 2014 at 10:08 PM
    #292
    TacoBrah
    Sean
    Is that something most local suspension shops could take care of? I just hate the idea of having to send in my COs for a week and let my truck sit there on jack stands.
  13. Feb 5, 2014 at 11:07 PM
    #293
    SoCalTacos
    SoCalTacos [OP] Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Some shops can do it...where you at?
  14. Feb 6, 2014 at 3:48 AM
    #294
    mike2100
    mike2100 Well-Known Member
    Virginia Beach
    TBD
    Keep your stock suspension to swap back in
  15. Feb 6, 2014 at 6:31 AM
    #295
    icon_rep
    Riverside, CA
    You will need to check with shops in your area, but if they have rebuilt other brand shocks they can do ours. I have had people use motorcycle shops as well, those are the same concept. We can always get someone on the phone with a shock tech if questions arise during the process as well. Glad to assist in any way we can.
  16. Feb 6, 2014 at 6:33 AM
    #296
    icon_rep
    Riverside, CA
    I def recommend this....it's not worth much, and way more valuable to you just in case.
  17. Feb 6, 2014 at 7:51 AM
    #297
    TacoBrah
    Sean
    Im in santa barbara.
    Guess it wouldnt be the end of the world to swap back on my stock struts for a week to get the COs rebuilt.
  18. Feb 6, 2014 at 7:56 AM
    #298
    icon_rep
    Riverside, CA
    If you are that close it would not be bad at all. You get them to us on Monday, we rebuild and ship them back on Tuesday (ICON service day) and you will have them Wednesday.
    If even 1 day is an issue, then yes keeping the stock suspension would be a good idea. Tires might rub a little, but if you take it easy you can get by ok.
  19. Feb 6, 2014 at 8:03 AM
    #299
    SoCalTacos
    socal
    There's some local guys near Santa Barbara that could rebuild them for you. Stop by the 805 members thread, there's a few fabricators/install guys that could help you out.
    Some nearby spots like poly performance, Viking offroad, kibbetech, DTF fab, Adam (dirty dangler)could do it for you.
  20. Feb 6, 2014 at 8:11 AM
    #300
    LazyLightning
    LazyLightning Member
    Nor Cal
    3" lift
    Where I live, a lot of guys are running King. They have stock UCA and sometimes stock springs. I've seen DBL cabs with caps and reg cabs. The guys I talk to say they love them. The ride is great. They do NOT have any issues. I'm going with Kings.
