king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Nov 12, 2015 at 3:00 PM
    #661
    T4RFTMFW
    T4RFTMFW Well-Known Member
    tdnick and scocar[QUOTED] like this.
  2. Nov 12, 2015 at 3:01 PM
    #662
    scocar
    scocar Patron of the Farts
    NGO
  3. Nov 12, 2015 at 3:40 PM
    #663
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Looks like it haha. You can tell it's different though just by some trim pieces like the side mirrors and door handles.
  4. Nov 13, 2015 at 6:17 AM
    #664
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Well put. I realize my post was on the "harsh" side. I overdid it a little. It just kind of ticks me off when someone is blaming someone else who did nothing wrong for what someone else did. I didn't really mean to imply I wouldn't buy King shocks based on what one or two people said about ICON based on behavior of the past owner. I'm going to have to look up what Donahoe actually did because it almost sounds as if he was partnering with the Taliban or was a serial killer or something.:confused: I'm still thinking about it and I've got a couple more months to think.
    Taco Suave[QUOTED] likes this.
  5. Nov 23, 2015 at 11:41 AM
    #665
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    This is an old post, but has Fox changed this in the past few years? Because all the specs I'm reading for these shocks say they use aluminum.
  6. Nov 23, 2015 at 12:36 PM
    #666
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Fox resi's are steel. King is aluminum. At least with the 2.5" and larger shocks. Both use steel shock bodies.
  7. Nov 23, 2015 at 12:59 PM
    #667
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    This thread makes me feel extra good about having icons on their way to my house :)
  8. Nov 23, 2015 at 1:09 PM
    #668
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    This thread makes me feel bad for humanity.
    Bookaroni, bullaculla, Crom and 3 others like this.
  9. Nov 23, 2015 at 4:58 PM
    #669
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    @jberry813 question for you on shock valving: how do valves handle reversing direction, for purposes of the shaft velocity vs damping force discussion?
    As I understand it, digresive valves provide less force as the shaft velocity increases. When the shock switches from compression to rebound does velocity go to zero for purposes of the damping force, or (assuming the rebound is as similar to the compression) does the shaft speed remain high?
    I think this may be better described looking g at the first derivative of speed?
  10. Nov 23, 2015 at 6:20 PM
    #670
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I'm not sure I entirely understand the question. Define "valves". Purely in terms of a smooth body, the piston has flow ports. Flow ports for rebound and compression are completely separate. When you switch directions from comp to rebound, the comp ports are blocked by the largest compression shim so all the fluid flows through the rebound flow ports. Same is true for a vice versa direction change. Velocity doesn't really matter regardless of brand. Icons have a dished piston that preloads the shims but the largest shim still acts the same way and blocks reverse fluid flow (unless you add a riser washer/shim which would allow for free bleed).
    Or are you asking about bypasses?
    Arcticelf[QUOTED] likes this.
  11. Nov 24, 2015 at 3:14 AM
    #671
    Arcticelf
    Gladiator
    No, asking about smooth body.
    Inthinknyou answered the question, which is that compression and rebound are unrelated?
    Put it another way: when looking at a damping force vs shaft velocity curve that is either for compression or for rebound? When the shaft changes direction you either switch to the other curve, or (if both were set the same) velocity goes to zero, then accelerates the other direction.
  12. Nov 24, 2015 at 8:03 AM
    #672
    Tacoma SS
    Denver
    Will I need extended brake lines for my icon 2.5 coilovers? They are not extended travel
    ChadsPride likes this.
  13. Nov 24, 2015 at 8:08 AM
    #673
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    No
    Arcticelf likes this.
  14. Dec 20, 2015 at 8:43 AM
    #674
    motozack
    motozack Well-Known Member
    zack
    Humboldt Ca.
    '07 2015 TRD pro clone MAGNUSON supercharged
    Magnuson S/C 2.85 stealth pulley Afe stage 2 sealed pro dry 255 URD fuel pump TRD Quickshifter & knob Method double standards 265/70/17 KO2's B.A.M.F. Sliders W/kickouts powder coated 2.5" kings W/resi's Camburg UCA's TRD catback exhaust 2015 TRD pro clone 2015 interior Pioneer Nav
    Super happy with my Kings, this thread on the other hand, wow.
    All three options are so much better than your basic shocks you can't go wrong. Let's face it 95% of us buying these setups aren't Bj Baldwin shredding through the desert.
    Weather your color choice is black, grey, or blue, the truck will be night and day better!
    Commence battle...
  15. Jan 14, 2016 at 10:44 PM
    #675
    Djboi808
    Djboi808 Well-Known Member
    2015 white Tacoma 4x4 Trd Off Road
    Very good info just read all 37 pages with all questions answered
  16. Jan 15, 2016 at 11:02 PM
    #676
    TRVLR500
    Wyoming
    I Really wanted Kings or ICONS but I went with OME. For what I do which is daily driving and very little off road use they work fine. I will say that although I am very happy with my OME which are a HUGE improvement over the worn out stock suspension I can easily see that King, ICON or ADS as well as another multitude of suspension manufacturers can deliver a superior ride. A ride that OME can't touch which is why they cost twice what OME costs. Other than the low speed harshness that OME shocks provide because they are designed to carry loads off road I have NO complaints. When it comes to on road handling they are fantastic. Off road they are a little harsh but I can deal with that since I don't do off road very often. I still have Kings or ICON on my wish list but for the time being I'm very happy with my OME. What you are going to use your truck for has everything to do with what suspension system you buy and what you can afford. Everything is a compromise. For me, OME is working quite well at this time.
  17. Jan 20, 2016 at 8:49 AM
    #677
    Dominus
    Dominus Well-Known Member
    Corey
    Pittsburgh
    12 Spruce DCSBOR
    Just read through 37 pages of this thread and have to say it has been extremely informational (but more so entertaining). After separating few facts from many opinions I think Taco Suave showed it best . . .
    See the difference in body roll at 12 sec in both these videos? that is the difference in digressive vs progressive. So for you weekend warriors who Daily your taco and do more than 70% highway IT REALLY DOESNT MATTER. both lean, both shocks go up and down and most wont know the difference. /rant
    I personally plan on going whatever I get a better deal on.
    for the next 37 pages, please read http://www.pirate4x4.com/tech/billavista/coilovers/Part_1/ before asking more questions :D also a big Thanks to jberry813 for keeping it real!
  18. Jan 20, 2016 at 1:35 PM
    #678
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  19. Jan 21, 2016 at 10:59 AM
    #679
    austin21
    austin21 Well-Known Member
    Austin
    Bend, Oregon
    2014 Super White Tacoma SR
    Cut springs
    Will i need extended brake lines with 2.5 extended travel kings?
  20. Jan 21, 2016 at 11:04 AM
    #680
    Arcticelf
    Gladiator
    Probably a good idea, but not absolutely required.
