king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Feb 11, 2012 at 9:05 PM
    #61
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    The other purpose of the resi is to act like an accumulator and affect the compression and rebound of the shock.
  2. Feb 11, 2012 at 9:05 PM
    #62
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Just to clarify......light racing upper control arms will work just fine with extended travel coilovers. the larger ball joint will articulate further than the shock can extend.
  3. Feb 11, 2012 at 9:07 PM
    #63
    jandrews
    '09 FourDubDee TRD OR
    I'm aware, but I don't think it would affect that significantly enough to matter, and I'd rather have the clearance.
    Think about where King and Fox mount their resis. Consider if the resi was on the backside of the same mounting bracket setup. I'd love to get 2.5" more clearance in the wheel well, and I'm sure there's plenty of airflow to make increased proximity to the engine a negligible factor.
  4. Feb 11, 2012 at 9:09 PM
    #64
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    They are all good. Pick a color or go for the one with the one that fits your budget.
  5. Feb 12, 2012 at 12:08 AM
    #65
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    285's clear no problem.
    If your going wider then that, you already know you need to modify a good deal of the truck and the suspension set up. In those cases I wouldn't want an off the shelf shock and would recommend getting something built.
    You can easily get a custom hose length and hose fittings in order to mount Kings anywhere you want. That's the nice thing about getting Kings from a reputable vendor vs from buying suspension from a warehouse. You tell the vendor what your needs and specs are and they build your suspension accordingly from their wide range of parts.
    Currently Icon and Fox do not offer a good choice of spring weight options for a 05+ Tacoma. One of the local guys I know had to get King 700# springs on his Fox 2.5's. I know that Icon's also does not offer a higher weight spring needed for a Tacoma with full armor/winch. I'm not up to date on their valving options, but I'm sure that's not an issue.
    Even the "vehicle specif" brands like Icon can't fine tune valving and spring weight in order to sell one model of a off the shelf shock that is set up perfectly for a light/fast Tacoma pre-runner and at the same time a slow/heavy armored rock crawler. It's just not possible. This is why I never listen to people when they say "My Icons are designed specifically for my truck and your Kings aren't". The funny thing is they couldn't be more wrong and in most cases it's the exact opposite.
    *ends drunk late night rant* :D
    Bookaroni and Mr.PowerTrays like this.
  6. Feb 12, 2012 at 12:16 AM
    #66
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Icon FTMFW! Think they put the most work in as far as tuning them to the right truck.....not just off the shelf! I know the low end compression can be adjusted on a re-valve as that's what most people tend to complain about. Personally though, I really like the firmness of the digressive valving...much more stable feeling!
    Acts as cooling and makes them more consistent throughout there travel I was told!
    FTW! My Camburg BJ's (no pun intended) will work well too! :D Nice build by the way, that truck is sick! Those "off the shelf" Icon's seem tuned pretty good for having extra weight up front!
  7. Feb 12, 2012 at 12:49 AM
    #67
    SoCalTacos
    SoCalTacos [OP] Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Sooooo...
    Jk..thanks everybody for the input.
  8. Feb 12, 2012 at 12:53 AM
    #68
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    That KR bumper in your pics is sick! Got any more?
  9. Feb 12, 2012 at 7:32 AM
    #69
    jandrews
    Yeah, but wider's not the issue...taller is.
    Cutting and pounding sheet metal is no big deal. But larger diameter = greater scrub radius. So when the time comes, I'll be dealing with probably cutting and new wheels.
    Icon can valve basically anywhere you want, but yeah, spring weight is kind of a PITA because they use a slightly shorter custom spring than the other two. Trying to shoehorn a 16" spring on an Icon setup results in binding.
    That said, they come factory with 650lb springs which is adequate (just barely) for a loaded front end. 700lb would be better.
    Yeah, the customization comes from the person building the truck, not the products going into it.
    So far, super happy with my Icons, and I'm gonna run with 'em til I'm not...at which point it will probably be time for not only new C/Os, but new links as well :D
  10. Feb 12, 2012 at 9:02 AM
    #70
    XXXX
    sKiP
    05 Prius
    I still :rofl: every time I read your sig. That thread was great.
  11. Feb 12, 2012 at 10:55 AM
    #71
    SoCalTacos
    socal
    Not mine...but it is sick. Members name is RAD.
  12. Feb 14, 2012 at 2:19 AM
    #72
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    where do you guys buy your king or fox shocks from??
  13. Feb 14, 2012 at 6:11 AM
    #73
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Down south motorsports!!! Amazing service, plus you get 1 free re-build.
  14. Feb 16, 2012 at 5:08 PM
    #74
    supremetaco2
    04inacoma
    ^^ sounds like a plan! Thanks
  15. Oct 29, 2012 at 7:46 PM
    #75
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I know this is an old thread. But where do Radflo's fit in the group of these shocks?
  16. Oct 30, 2012 at 6:24 PM
    #76
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Although I do not have experience with Radflo, I know they are considered one of the upper echelon shock manufacturers and should be able to offer the same tunability and customization as the rest. I am considering them for my next set of rear shocks b/c King and Fox cannot offer what I am looking for at a similar price point. Others please chime in.
  17. Oct 30, 2012 at 6:32 PM
    #77
    Mitch
    Mitch
    Spokane, WA
    I was about to go with them. But decided to join the Icon train. Ordered a set today
  18. Jan 3, 2013 at 6:18 PM
    #78
    SoCalTacos
    socal
    35's should be okay as far as the resi is concerned...the cab mount and inner fender plastics may need some trimming though.
    Dead.
  19. Feb 7, 2013 at 1:19 AM
    #79
    EVErsionDesigns
    EVErsionDesigns Well-Known Member
    '11 4wd TRD OffRoad
    Camburg UCA, 2.5" Icons, 2.0" Icon air bumps, TRD Intake, TRD Exhaust, TRD TT Wheels, OMF Beadlocks, BFG
    I have a question for you all.
    Is the OEM replacement King an extended travel shock like the extended travel Icon is???
  20. Feb 7, 2013 at 2:12 AM
    #80
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    No, but DSM offers an ext travel king. Although Sonny says it's only 1/8" at the wheel.
