king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Jun 22, 2016 at 2:59 PM
    #781
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Brain explosion.
  2. Jun 22, 2016 at 3:45 PM
    #782
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Ok let's try to get this sorted out.
    Conseptualizing what is actually happening inside a shock in order to tune it is very difficult. When a shock is progressive, the faster the shock is moving, the more force it makes. This does not mean that the more the shaft is compressed, the more force it makes. That is the difference between something that is displacement (a spring) and something that is velocity dependent (a damper).
    So, say you hit a bump with a progressive shock. Now let's say that the bump causes the shock to use the entire shock travel with the point at which the shaft is traveling the fastest at the exact middle of travel. This will create a force graph that looks similar to a sine wave relative to the shafts travel. This is because it goes faster and faster until it hits mid stroke, then starts to slow down more and more. So the point at which the shock is producing the most force is at mid stroke because that is when it is traveling fastest. Then makes less and less force until it stops moving because it has absorbed all of the force or it stops because it bottoms out.
    So when you hit stuff harder, it reacts by producing more force because the shaft will be traveling faster.
    For a digressive shock, the characteristics are different in regards to transitioning from low speed to high speed. This means that your not going to feel it be stiff at first and then give out and loose compression during one bump. What it means is that when you hit something going slow (low speed) like a speed bump or drive way, it will feel like a stiffer shock. However when you hit something going faster (high speed) like a whoop or a pothole on the road, it will feel like a softer shock.
    With your first braking analogy which you said was progressive, you are braking harder the further you keep going into the stop. That is a displacement dependent reaction.
    With your second analogy which you said was progressive, you start braking hard because that's when your going fastest and then slowly give less and less force to the brakes because you are slowing down. That is velocity dependent, and when comparing to shocks, both progressive and digressive shocks do that at one given speed. It's the transition from multiple speeds (usually looked at as low speed to high speed) that makes the shock be digressive or progressive.
  3. Jun 22, 2016 at 6:39 PM
    #783
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Them digressive vlaves do better on duh road, boyo!
  4. Jun 22, 2016 at 8:20 PM
    #784
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
  5. Jun 22, 2016 at 8:33 PM
    #785
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Thanks all for the inputs. The mod bug is itching, but I'm going to try and hold off until I get to actually ride in some rigs with different setups.
    I would have figured the Foxs would be smoother on the street than the Icons- maybe the spring rate is stiffer. Another consideration I need to keep in mind, I would like to run a plate bumper in the future.
    Well... hell... I've heard the "just pick a color" so many times, I'm becoming a believer haha. Not a fan of the King's blue to be honest, and live near the coast so salt air is a factor.
    I think somewhere early/mid this thread this is brought up.
    Speaking of stuff brought up much earlier in the thread, the comments that the dampening adjustment option some brands offer are fluff. My car has Tein Flex with EDFC, so I'm a bit spoiled to the joys of making minor adjustments without needing a rebuild. This removes King (didn't see that as an option for 1st gen systems) and keeps Fox and Icon on the list.
  6. Jun 22, 2016 at 8:36 PM
    #786
    digitaLbraVo
    @BlackSportD if you trust the force graphs provided by Icon the adjusters actually do help quite a bit.
    Also: you can have King custom made in any color you want...
  7. Jun 22, 2016 at 8:56 PM
    #787
    BlackSportD
    Los Angeles
    Mmmmm... adjusters
  8. Jun 22, 2016 at 8:57 PM
    #788
    digitaLbraVo
  9. Jun 22, 2016 at 9:16 PM
    #789
    BlackSportD
    Los Angeles
  10. Jun 28, 2016 at 7:35 AM
    #790
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    King is doing that same design now. I will post a picture soon with the way it looks. I'm trading out my icons for kings
  11. Jun 29, 2016 at 2:00 PM
    #791
    BlackSportD
    Los Angeles
    Why are you trading from Icon to King? Just curious.
  12. Jun 29, 2016 at 3:50 PM
    #792
    mrbedgood
    North Carolina
    I don't drive as fast as they need to drive smooth, since they are a digressive shock. Plus I just added TC UCAs, LCAs, and about to add armor, went with what the company owner from where I'm getting the armor from recommended.
    BlackSportD[QUOTED] likes this.
  13. Jun 30, 2016 at 11:42 PM
    #793
    mrbedgood
    North Carolina
  14. Jul 1, 2016 at 5:41 AM
    #794
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    :drool::drool::drool:
    did king change the way the resi mounts? vertical now?
  15. Jul 1, 2016 at 5:47 AM
    #795
    603fishhunter
    603fishhunter Well-Known Member
    Forrest
    New Hampshire
    2014 tacoma 4 cyl access cab
    6" rough country lift
    I have the 6" rough country lift, don't have the money quite yet but I'm shopping around to ditch the blocks and spacers. Icon makes a 6" lift shock/coil over compatible with a pro comp lift. Does anyone know why/if they only work with pro comp? Do certain brands dictate what uca's I'll need? Open to other options if there are any I'd like fox I just feel like the whole point of the upgrade is to lose spacers.
  16. Jul 1, 2016 at 5:57 AM
    #796
    mrbedgood
    North Carolina
    Yep King redesigned their mount to a vertical mount. It's pretty beefy too
  17. Jul 1, 2016 at 8:18 AM
    #797
    BlackSportD
    Los Angeles
    :eek::eek::eek::eek:
    Whats the verdict on the ride?
  18. Jul 1, 2016 at 8:58 AM
    #798
    mrbedgood
    North Carolina
    It rides wonderfully on the road. It really feels like I'm rides stocks suspension again, it's that good. Measurements, with full tank of gas:
    Before:
    DF: 22"
    PF: 22.5"
    DR: 24.5"
    PR: 25"
    Now:
    DF: 23.25"
    PF: 23.5"
    DR: 24.5"
    PR: 25"
    Boba Fetty likes this.
  19. Jul 1, 2016 at 9:04 AM
    #799
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Did you get the extended travel?
  20. Jul 1, 2016 at 9:05 AM
    #800
    BlackSportD
    Los Angeles
    I take it thats a nice smooth compliant ride in 2nd gen talk? I'm a 1st gen and the OEM suspension was nothing to brag about in regards to street manors (smoothness) haha. And this is with stiffer springs up front in anticipation of armor additions?
    I'm leaning more and more towards Kings, and wheelers off-road has more options that DSM for 1st gens. My wallet is going to be pissed...
