king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Aug 25, 2016 at 7:52 AM
    #841
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Bottom line is, depending on location and the weather you see, your shocks are gonna rust out. If you're where they salt the roads, and you don't spray your shocks down every so often, chances are they're gonna rust. Down South Motor Sports does excellent work and can really clean up shocks if needed during a rebuild. I had an old set of Foxes that were pretty rusty and DSMS made them look pretty new with a rebuild
  2. Aug 25, 2016 at 8:07 AM
    #842
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    wish we were closer... to have a try out of your shocks. i lean on fox and king with adjuster even thought they are over kill for my need( pavement only). not a fair question, but out of the three which one you prefer most on performance.
  3. Aug 25, 2016 at 8:25 AM
    #843
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Kings. You don't need adjusters. Adjusters are only good if you drive fast Offroad. I have a longer explanation somewhere on here about not needing them. And I got my info straight from King.
  4. Aug 25, 2016 at 9:48 AM
    #844
    jtv
    thanks again for your inputs. i really missed that post and i need to go back for it. last question, if adjusters are not needed for pavement, then r/r also not needed?
  5. Aug 25, 2016 at 9:59 AM
    #845
    mrbedgood
    North Carolina
    Its no problem. here is what I posted once.
    I got some great advice from Tyler Pelfrey and a gentleman at King about the purpose of the adjusters. Let's say I was Baja racing or driving my truck fast somewhere off-road where my truck would need more compression and then coming back on hard ball to utilize it as a daily driver, then yes I would need an adjuster. I use my truck for daily driving and camping. It would not service the purpose to increase compression and the lowest setting puts it back to a "stock/factory" compression, doesn't make it any softer than what comes out of the box for the regular remote reservoir ones. And since I live in North Carolina which is very similar to Alabama, with rocky and wooded areas I figured just go with the non-adjustable ones.
    Are R/R necessary? Absolutely! I went from Icon non R/R to King R/R. Yes one is a progressive coil over and the other is a degressive, but having the R/R allows the oil to flow when it heats up. Which in turn gives you that comfort both on and off road. All King's come with R/R, they really don't consider it an opition not to have.
  6. Aug 25, 2016 at 10:44 AM
    #846
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Oil "flowing" has nothing to do with a resi. A resi has an internal floating piston which separates the nitrogen cavity from the oil cavity. As the shock compresses and the shaft displaces fluid, the fluid flows through the resi and the oil cavity increases while the nitrogen cavity shrinks (which increases nitrogen PSI) until the shock rebounds. Non resi shocks that are NOT emulsion shocks also have an IFP in the shock body itself that separates the two cavities. A resi just gives you larger oil capacity. And yes, you can absolutely buy kings without the RR and save some coin.
  7. Aug 25, 2016 at 10:53 AM
    #847
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    @jberry813 I want your trailer...
    your truck is cool too. :thumbsup:
    jberry813 likes this.
  8. Aug 25, 2016 at 12:16 PM
    #848
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
  9. Aug 25, 2016 at 12:39 PM
    #849
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's a great start, but not completely comprehensive. It doesn't show setting IFP depth and rebuilding bypass seals.
  10. Aug 25, 2016 at 12:59 PM
    #850
    CedarPark
    Dylan
    Cedar Park, TX
    We've all got to start somewhere, I didn't know those videos existed. Living in Texas there's not a large following behind high quality IFS suspension so there's not really anyone to learn from.
  11. Sep 11, 2016 at 12:09 AM
    #851
    VolkswagenTaco
    VolkswagenTaco Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    Looking on getting the king setup with ext resi's from down south motor sports. I've read all 45 pages here and looks like I'm going with King. Any opinions?
  12. Sep 11, 2016 at 5:38 AM
    #852
    jtv
    Hell yeah, I read enough and pulled the trigger on Friday from HeadStrongOffRoad, King on all four corners. I didn't know how many pages I read, but I did it for almost two months on the big three. Yes, this is my first truck (since 2012) and my first lift.
    scottalot likes this.
  13. Sep 11, 2016 at 6:27 AM
    #853
    VolkswagenTaco
    Sean
    Compton
    Nice. Any pics of the final outcome?
  14. Sep 12, 2016 at 6:47 AM
    #854
    jtv
    Not receive them yet. They ship them out today, 9.12.16.
  15. Sep 14, 2016 at 4:48 PM
    #855
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I know King offers a 700# coil, but to my understanding that is not their standard coil. Does anyone know what is the weight rate for king's standard coilovers?
    Not sure if that was mentioned yet in this thread, if so I apologize.
    Thanks guys.
  16. Sep 14, 2016 at 4:50 PM
    #856
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    600#
  17. Sep 14, 2016 at 4:59 PM
    #857
    CountryDan
    Daniel
    Calhoun GA
    Thanks.
  18. Sep 14, 2016 at 6:22 PM
    #858
    mrbedgood
    North Carolina
    Go with King and go with Micah at @Downsouth Motorsports you won't be disappointed.
  19. Sep 14, 2016 at 6:23 PM
    #859
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  20. Sep 14, 2016 at 6:25 PM
    #860
    mrbedgood
    North Carolina
    standard is a 14" x 600#
    I'm running a 650# due to going with an aluminum pelfreybilt bumper and winch.
