king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Mar 8, 2017 at 3:37 AM
    #1121
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Pretty sure king 05+ Tacoma OEM come standard with 600#.
  2. Mar 8, 2017 at 4:40 AM
    #1122
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I think the standard Toyota suspension is about 590# from the factory so that it is soft for on road manners with no heavy stuff. My kings came with a 650# spring.
    Coot
  3. May 3, 2017 at 7:59 AM
    #1123
    roadrashchic
    roadrashchic Well-Known Member
    Jessica
    boo-kay
    2015 Black TRD Sport double cab
    Engine: K&N filter CAI Suspension: KING 2.5" Rem. Res. Ext. Travel Coilover w/Comp Adj (front and rear). Total Chaos Uni-Ball UCA’s and Deaver J66 1.5" Rear Leaf Pack. Tires: 285/75/16 BFG KO2's FUEL WHEELS D525 REVOLVER MATTE BLACK AND MILLED Exterior: Pelfreybilt sliders and hybrid front bumper/skid Front-runner Roof Rack, slim-line II, bed rack, tent, and 3 INCH LED 16W FLOOD LAMPS, (mounted to the hood via rentlentless fabrication mounts.) WishList: (pending soon..) bushwacker fender flares 40" LED bar winch rear high clearance bumper bigger tent with higher bed rack
    So my suspension sunk in.. and I started rubbing the cab mount pretty decent. so I raised my front about an 1". No more rubbing, but I feel vibration on the high way.. and overtime I hear "clink, Clack" or something like.. I freak the F**k out like a bolt snapped off or something.. even though it was probably just a rock in my tire getting loose, lmao. my rear end is sagging ass a lot now too..
    WTF?! :(
  4. May 3, 2017 at 8:14 AM
    #1124
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    The vibes could be related to the front diff needle bearing. Do the vibs go away when you take your foot off the throttle?
    Coot83 likes this.
  5. May 3, 2017 at 9:44 AM
    #1125
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You realize the first time you flex out your front end you're gonna rub. Lift does not clearance anything, it merely let's you drive. Would hate to hit a large bump in the road doing 60 and have a tire slow itself down on the cab mount, would not be a fun time. Let alone off road.
    Coot83, Arcticelf and deeezy like this.
  6. May 3, 2017 at 1:11 PM
    #1126
    roadrashchic
    Jessica
    boo-kay
    I'll pay attention when I drive home from work today! thanks!
  7. May 3, 2017 at 1:12 PM
    #1127
    roadrashchic
    Jessica
    boo-kay
    so you're saying I should do the cab mount chop mod?
    Coot83 likes this.
  8. May 3, 2017 at 1:19 PM
    #1128
    VolcomTacoma
    Jeff
    NorCal
    Yes. What size tires are you running.
    All a lift does is move the suspension down, you aren't gaining any extra travel, so unless you adjusted your bumps down, at some point you're going to stuff your tires on something and without clearancing for the larger tires you're now back where you started. Obviously not all the time, but like I said, imagine going around a corner at some speed and there's a bump there that flexes out the suspension a little bit, suddenly your tire is smashing the cab mount or pinch weld and either rubbing hard enough to stop the tire (doubtful) or create enough stress to break stuff. Pinch weld is easy enough to massage flat with a mallet, that way you're not slicing tires.
    Bottom line is, if you get larger tires and you rub at any point, you need to clearance.
  9. May 3, 2017 at 1:24 PM
    #1129
    roadrashchic
    Jessica
    boo-kay
    285/75/16 BFG KO2's
  10. May 3, 2017 at 1:25 PM
    #1130
    roadrashchic
    Jessica
    boo-kay
    I need to make a trip to Cali.. i have a lot of friends out there that would be able to do it for me... nothing here in ABQ.. and I don't have the tools to do it myself. (at least I don't think.)
  11. May 3, 2017 at 1:28 PM
    #1131
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    All you need is a grinder with a cuttoff wheel and a BFH.
    Takes about 15 min per side.
  12. May 3, 2017 at 1:29 PM
    #1132
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I have the exact tires. Heavily recommend CMC with the small plates. I cut for 35s just so I know at this size there is no way I will make contact since im LT.
    roadrashchic[QUOTED] likes this.
  13. May 3, 2017 at 1:30 PM
    #1133
    roadrashchic
    Jessica
    boo-kay
    haha I just looked into... I think I feel confident to do it.. hmmmm :sawzall:
    Coot83 likes this.
  14. May 3, 2017 at 1:32 PM
    #1134
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would recommend ordering the plates or seeing someone who has had it done. You will realize if you dont already that it doesnt take much of a chop to get this done. Cutting to me is the easy part. I even went a few weeks before I got mine filled. Structurally they dont need the plate, but to keep debris and stuff you want to eventually seal it. My stuff is completely boxed now.
  15. May 3, 2017 at 1:43 PM
    #1135
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    You should see my rear body mount, its literally just an L (but upside down) :oops:
    roadrashchic likes this.
  16. May 3, 2017 at 2:06 PM
    #1136
    roadrashchic
    Jessica
    boo-kay
    is there a company that sells the pre cut plates?
  17. May 3, 2017 at 2:07 PM
    #1137
    roadrashchic
    Jessica
    boo-kay
    or do you just cut, trim, and re weld?
  18. May 3, 2017 at 2:08 PM
    #1138
    roadrashchic
    Jessica
    boo-kay
    sorry just found relentlessfab... hahaha..
    Coot83 likes this.
  19. May 3, 2017 at 2:32 PM
    #1139
    Boomkanani
    Goldsboro, NC
    Some stuffz
    BAMF also sells the plates
  20. May 4, 2017 at 3:10 AM
    #1140
    Arcticelf
    Gladiator
    Plates are not a bad idea, but by no means required. I plated mine with some 10ga because I had it handy.
