king vs. icon vs. fox racing coilovers
Discussion in 'Suspension' started by SoCalTacos, Feb 10, 2012.
Coilover Preference?
  1. Fox Racing
    228 vote(s)
    25.1%
  2. Icon
    291 vote(s)
    32.0%
  3. King
    342 vote(s)
    37.6%
  4. ADS
    49 vote(s)
    5.4%
  1. Sep 1, 2017 at 7:29 AM
    #1201
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    I run #2 click on my icons full time, off roading (30-60mph on dirt) and highway (160mph) with no sway bar.
  2. Sep 1, 2017 at 7:35 AM
    #1202
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Holy cow!!!!!! 160mph. I bet that's a little scary.
    Lord Helmet likes this.
  3. Sep 1, 2017 at 8:55 AM
    #1203
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Roland79, deeezy and Lord Helmet like this.
  4. Sep 1, 2017 at 1:12 PM
    #1204
    wheeliest
    Json
    TMPE AZ
    160mph is a complete lie, the rest is the truth!
  5. Sep 2, 2017 at 1:33 PM
    #1205
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    CDCV helps a bit. I have been running it stiff (8 I think) on the street to reduce body roll and get used to the feel of what its going to be like when I pre-load some more (then will just click softer after that). The 'low speed stack' sounds like it would alleviate a lot of my gripes with the overall valving on my Icons.
    Aiming to use CDCV like Lord Helmet uses the King setup, soft on the street cause I don't need to feel crap, and driving fast on the trail cause I don't want to bottom out- built some one-off sway bar quick disconnects so I can run soft on the street and not worry about my last run-in with emergency steering sway. Reading on a Raptor forum on King vs Fox vs Icon, guys were talking about adjusting stiff on the street, soft on the off road, I was like, "whaaaaat?" I want that Lexus/Caddy ride on the street, and be able to barrel down the trail with a grin that I'm not hitting the bump stops.
    Lord Helmet and Plannerman99 like this.
  6. Sep 7, 2017 at 10:54 AM
    #1206
    zuPROc_TRD
    zuPROc_TRD Well-Known Member
    SoCal
    2017 Tacoma TRD Pro named CeCe
    sub'd for future reference
  7. Sep 7, 2017 at 1:33 PM
    #1207
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    FOX if you drive at winter. I don't know if anyone else (King, ICON or ADS) offer better oil than FOX's JM92.
    *TRD* likes this.
  8. Sep 7, 2017 at 3:59 PM
    #1208
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    King & Fox valve them too soft unless you're only concerned about the street and washboard.
    Any bumps at all and you blow through the travel.
    Icon valves too stiff IMO. I didn't like them on road or off-road.
    The Fox high and low speed adjusters are the most useful: http://accutuneoffroad.com/articles/how-fox-dsc-dual-speed-compression-adjusters-work/
    King adjusters are functional, but they're not linear and the design is odd: http://accutuneoffroad.com/articles/how-king-compression-adjusters-work/
    No data on ICON adjusters yet
    Fox & King comparison: http://accutuneoffroad.com/articles/fox-vs-king-2-0-coilover-shock-comparison/
  9. Sep 7, 2017 at 4:01 PM
    #1209
    RandyRiot
    RandyRiot Well-Known Member
    Randy
    Los Angeles, CA
    2016 Tacoma TRD Sport
  10. Sep 7, 2017 at 9:51 PM
    #1210
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    They do custom valving and it sounds like you are simply describing the progressive and digressive difference with kings and fox vs icons...
    Do you have any of these shocks?
  11. Sep 7, 2017 at 10:08 PM
    #1211
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    You drop a truth bomb here. I went with FOX 2.5 IFP (no remotes) that came with 600#, 13" springs. They rode a little stiff at first just mostly stock, added the ARB and dual batteries and they rode well in all conditions. Decided to bump up to 650#, 14" because I was turned fairly far down to get 2" of lift and was anticipating the winch and skid plates.
    Didn't want to do a re-spring twice. The ride was stiff until I added the winch and it's just OK now, but not cushy but less buckboard. I'm still not sure 650# is the right spring rate but it 'wheels well and I don't need the sway bar so I'm happy. The washboard ride is excellent, it does OK crawling but a little stiff. I think there's some valving fine tuning that could be done on my suspension, too.
    Ultimately just agreeing with your point on 650# and 700# springs. Carefully consider what you're doing. I'll be adding some additional skid plate weight but I can't imagine any Tacoma getting enough stuff bolted on to justify 700# springs without being really overloaded.
  12. Sep 8, 2017 at 7:25 AM
    #1212
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    While I agree Kings are built with standard valving to be soft, unless you are mobbing at 40 mph on OEM kings then the majority would be ok. If 40+ mph is what folks are going for...that is what LT apps are for which at that point people start getting bypasses. Not that bypasses supplement for any sort of valving, but def help for what you need at that level.
  13. Sep 9, 2017 at 5:19 AM
    #1213
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    I looked up Kings and found some negative stuff . I've always used icons on my jeeps and now Tacoma . No problems.
    I've also read a lot of great things about Kings.....
    I've used Fox before , they work well. But I've read some bad about them.
    I think you will will find some bad reads on all three, Icon, King , fox. There all great gear . Go with any and you will be happy.
    I like Icon and Fox personally because I've never used Kings.
  14. Sep 9, 2017 at 5:27 AM
    #1214
    Tacomamike mike
    Michael
    That's pretty funny.
    I thought the jerky guy was driving Kings at 16! Lol get Icons .
    4x4yotaphan[QUOTED] likes this.
  15. Oct 9, 2017 at 2:35 PM
    #1215
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
  16. Oct 9, 2017 at 3:54 PM
    #1216
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
    I was pretty set on Kings, when I go to do my lift. But I’ve been reading a lot of good things about ADS. So Its between Kings and ADS for me. I have a bit to decide, it will be a year or two before I do it.
    TACOVRD likes this.
  17. Oct 9, 2017 at 3:59 PM
    #1217
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Specs on ADS shocks seem top notch and in some ways superior to a lot of the other brands.
    Roland79[QUOTED] likes this.
  18. Oct 9, 2017 at 4:33 PM
    #1218
    Roland79
    Dave
    Missouri
    That’s kind of what I’ve been hearing/reading.
  19. Oct 9, 2017 at 6:59 PM
    #1219
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
  20. Oct 9, 2017 at 7:06 PM
    #1220
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    You are saying the Fox 2.5's are soft? Not so sure about that.
    *TRD*[QUOTED] likes this.
