Kings 2.5 and leaf springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jq1604, May 23, 2019.
  1. May 23, 2019 at 4:24 PM
    jq1604
    jq1604 [OP] Well-Known Member
    2017 Toyota Tacoma TRD Off Road 4x4
    Kings 2.5 lift kit
    Hey so Im about to take the plunge on buying Kings 2.5, both front and rear with adjusters, but ive been unsure of what type of leaf springs i should add to the rear. I was originally going to go with Dakars thru DS M but they are a 2.5 inch lift and i kind of want to get rid of the rake. I want my tacoma to look more level.
    I was wondering if you guys could advice me on leaf springs and tell me your experiences with them
  2. May 23, 2019 at 5:56 PM
    SpeySquatch
    2016 TRD OR DCSB
    Dakars, Alcan or Icon RXT leafs
    Rake is good btw. Helps stability, stopping power and carrying a load.
    I use to be level and have since decreased the front ride height to only 1.5” of lift and it rides way better IMO
    Also, if you are running any additional front weight (bumper, extra battery, winch, etc) then 700# springs would be ideal. Otherwise run the 650# springs.
    The 3rd gen front end is much heavier (300#) than the 2nd gen
  3. May 23, 2019 at 5:57 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Deaver sua packs
    jq1604[OP] likes this.
  4. May 23, 2019 at 6:12 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Hey man, shoot me a PM. I’d love to help throw some technical info at you and get you set up exactly for your needs.
    I can also hook you up on all the parts with a whole package deal.
    Hope to work together :fistbump:
    jq1604[OP] and whatstcp like this.
  5. May 23, 2019 at 6:16 PM
    jq1604
    Kings 2.5 lift kit
    @SpeySquatch I knew that the rake was to keep it leveled while towing stuff but i didnt know it was to keep stability and better ride overall. Thats good to know. If i do get the dakars do you know if a shock re-location is needed? Im planning to lift the front by 2.5 inches which would give 22.5inches of lift in the front and with the dakars 23.5 in the rear which would be perfect for rake then.
    (read somewhere that stock height is 20 inches in the front and 21 in the rear)
    Any pros and cons regarding alcons or icons rxts?
    And Yup im planning to buy 650s not planning on adding any front bumper any time soon
  6. May 23, 2019 at 6:21 PM
    SpeySquatch
    2016 TRD OR DCSB
    Think about the physics of rake. When you brake, downward force is applied to the tires which is then applied to the ground. If you are lifted and level the downward force changes a bit, but not a lot to worry about, just something to consider. Also when cornering the tire pressure to the road is affected with more or less take due to body roll and a few other things. If you look carefully, even desert racing trophy trucks have rake, the front just looks higher when they are driving because those bad boys have so much power and $50k suspensions that they lift very easy
    If you are running a TRD OR the front stock height from center of wheel should be 21”. Rear should be 22” stock center of wheel to fender.
    I run the Dakar medium (6-leaf) pack and my rear sits at 24”. I just adjusted my front coilovers to only have 1.5” of lift which put me at 22.5” in the front.
    The best feedback about the icon leafs is that they are adjustable if you are inclined, ride nice, and don’t squeak.
    Alcan can have a custom leaf pack tailored to your needs
    Hope this helps
    jq1604[QUOTED][OP] likes this.
  7. May 23, 2019 at 6:25 PM
    jq1604
    Kings 2.5 lift kit
    @whatstcp Yea i wheel every now and then. Maybe once a month not to often , but whenever i get the chance i take it!
    I dont tow or haul which is why i was considering to level my truck but after hearing that it loses some stability i dont see it worth it. Rather have an inch of rake to help with that issue.
    Im trying to find a middle ground where i find it smooth on the highway or atleast stock smooth and better with off roading for sure.
    Im already making a plunge with
    Kings 2.5 front and rear w/ comp adjusters and a total chaos UCA so i dont mind spending more for good leafs ‍
  8. May 23, 2019 at 8:31 PM
    SpeySquatch
    2016 TRD OR DCSB
    Lol. It doesn’t lose stability it is just decreased by a small amount. There are tons of guys that have driven lifted trucks for a very long time with no issues. Myself included.
    Any time you mod a stock truck you lose some of the engineered design. Just depends on what you’re willing to sacrifice.
    With that, have you researched any other shocks besides Kings? There are other shocks out there that are cheaper and by the sound of it, will fit your needs. Kings aren’t the “best” shocks... Every shock type and valving has a purpose,...but they do have a pretty blue color and a big name in the racing world
    whatstcp and Dirk Diggler like this.
  9. May 23, 2019 at 11:36 PM
    BeaverNation
    BeaverNation Well-Known Member
    Agreed. I fell Into the you need a full leaf pack trap after listening to people on here for years. Couldn’t stand the ride. Progressive 3 leafs outperform full replacement packs on vehicles that aren’t constantly weighted down.
    jq1604[OP] and whatstcp[QUOTED] like this.
  10. May 24, 2019 at 7:05 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Deaver all the way. U402s should do the trick they are more expensive than Dakars but are higher quality
    KrnTaco08, jq1604[OP] and KGTaco like this.
  11. May 24, 2019 at 9:21 AM
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    Deavers get my Vote too.
    If you aren't planning on Carrying equipment, I would say the Deavers J66 set. Gonna be softer than U402.
    I hate to be that guy too and make you spend more cash, but Rear bumpstops would be a nice addition when you do springs. If you don't off-road no point
    KrnTaco08 and jq1604[OP] like this.
  12. May 24, 2019 at 9:25 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Check out @Blackout14s leaf packs. He will probably have what you are looking for, I'm about to order some leaf packs from his this summer.
  13. May 24, 2019 at 10:26 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Deavers FTW...
    Besides quality and made in the USA, I like it for the berlin shackle eye. Places the main leaf centered with the bushIng for less side-to side deflection and has better overall movement.
  14. May 24, 2019 at 10:27 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Do they make a leaf pack for stock ride height / no lift?
  15. May 24, 2019 at 11:42 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    I'm running King 2.5's with Icon RTX leaf pack in configuration 1 (how they ship). The ride is great and has no squeaks. The rear is at 23.5" and the front is at 23"
    This isn't the best pic since the ground is not level but gives you an idea of how it sits.
  16. May 24, 2019 at 12:17 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Is there different stages on the U402s? The one I found was a stage 3 with 2” lift. Thanks.
  17. May 24, 2019 at 12:25 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Different stages are for handling different amounts of weight while still providing lift. I think the U402 stage 3 was 500-700lbs extra constant weight IIRC.
    KrnTaco08[QUOTED] likes this.
  18. May 24, 2019 at 12:27 PM
    KrnTaco08
    LA
    2017 Taco
    Awesome thanks.
  19. May 24, 2019 at 12:30 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    johntoyota likes this.
  20. May 24, 2019 at 12:34 PM
    KrnTaco08
    LA
    2017 Taco
