Kings vs Fox vs Icon
Discussion in 'Suspension' started by avitaco, Jun 11, 2017.
  1. Jun 12, 2017 at 2:04 PM
    avitaco
    avitaco [OP] Well-Known Member
    A
    2017 DCSB 4x4
    thanks for that info!
    what about the 6112? is that the same as the other in terms of generic?
    chris4x4[QUOTED] likes this.
  2. Jun 12, 2017 at 2:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    From what I have found, yes.
    avitaco[QUOTED][OP] likes this.
  3. Jun 12, 2017 at 2:24 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Lift isn't how you clear tires. Unless you add a bump stop or change some geometry your tire is still going to be stuffed into the wheel well the same amount as stock.
    Wishbone Runner, jberry813 and FinnJ like this.
  4. Jun 13, 2017 at 1:07 PM
    Glamisman
    Glamisman Well-Known Member
    In keeping with the original question... service after the sale is just as important as the product themselves, having said that, I need some replacement shafts for my sand rail. I was informed today that Fox is at minimum 3 months out for production. I sure hope that I can get these parts before desert season starts in October. I just might be converted to King.
    Been a while, anyway, Kartek had the shafts in stock for those of you that might need better service.
    avitaco[OP] and Coot83 like this.
  5. Jun 13, 2017 at 2:25 PM
    avitaco
    A
    2017 DCSB 4x4
    Talk to @dirtedreamer about that. He might be able to help you sooner than 3 months... yikes
  6. Jun 30, 2017 at 8:17 AM
    Mahmer09
    Mahmer09 Well-Known Member
    Ladera Ranch, CA
    2017 TRD Off Road 4x4 DBLB (Super White)
    How did you like the 6112 set up over all? Are you much more impressed with the Kings? I am debating between 6112/Fox/Kings. I am willing to wait and save. I just wonder in the end if I really need Fox or Kings. I am pretty set on a 1.5 inch lift, 265/75/16 tires. I like to off-road but am pretty new to it and can't see going crazy. Thanks!
  7. Jul 3, 2017 at 2:47 AM
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    Fox and King have linear pistons which can be progressive with an aggressive flutter stack. But the way most of these are tuned is close to linear.
    I know Icon used to sell digressive 2.0 shocks because I was an engineer at the factory where they were made. But I'm not sure if their new shocks are digressive, would need to see a piston.
    Digressive has better handling at the expense of small bump compliance. Linear is the way to go for Tacoma shocks.
    Here's an article comparing Fox and King. http://accutuneoffroad.com/articles/fox-vs-king-2-0-coilover-shock-comparison/
    Here are a couple articles comparing their adjusters:
    http://accutuneoffroad.com/articles/how-fox-dsc-dual-speed-compression-adjusters-work/
    http://accutuneoffroad.com/articles/how-king-compression-adjusters-work/
    802yotoclmbr, Lord Helmet and Coot83 like this.
  8. Jul 3, 2017 at 11:53 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  9. Jul 4, 2017 at 3:17 PM
    avitaco
    A
    2017 DCSB 4x4
    So, I've had the kings for a while and I can give some honest feedback
    First, I really liked the city drivability of the 6112/5160 set up. It handled very well in LA and the crappy roads making the ride 10x's better than the oem set up. It absorbed the bumbs very well. That being said, it didn't handle large bumps and bottoming out very well. It was very harsh but only on the worst of the large bumps.
    The Kings don't handle as well on the small bumps of the city. It's not bad at all and better than the oem set up as well but it's a tiny bit bouncy. Maybe I haven't found the perfect stiffness with the adjustable ability. On the the bigger bumps it's much better. Much much better. It handles a bottom out as well. 40/50mph on fire roads is no issue. Where the others would struggle on that. It's better the harder you push them.
    So there is my honest feed back from having both.
    I really enjoyed my 6112/5160 set up. And if you're going to do some mild off road (not rock crawling and a little slower on the fire roads) this is an excellent set up and an amazing bang for the buck. At around 1k this application would be great for 90% of people. If you like to push it a little harder and like to drive fast on dirt. The kings are amazing but you'll enjoy them less around town than you would the others.
    Hope this helps and you guys get what you want
  10. Jul 21, 2017 at 4:31 PM
    taco 16
    taco 16 Well-Known Member
    Lance
    San Diego
    2016 DCSB TRD Sport 4x4
    I noticed you are 4x4 with a 2.5" lift, did you do a diff drop and/or extended brake lines to compensate for extra 1" drop? Just asking because I'm looking to do the same setup. Thanks
