Kirkland battery good for the 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lunabird, May 30, 2019.
  1. May 30, 2019 at 10:42 PM
    Lunabird
    Lunabird [OP] Well-Known Member
    i was just watching Scotty Kilmore on YouTube, he was saying Optima batteries where junk. It got me thinking about Kirkland Costco batteries. Has anyone had any experiences with Kirkland Costco batteries? My OEM probably will need to be changed by the end of the year.
  2. May 30, 2019 at 11:49 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    Never had an optima fail on me. But they are by no means cheap. If you don't have a need for the load then definitely look at more valued options. Costcos Kirkland brand is pretty well establish as being as good as the leading competitor. Sometimes they're even just the good stuff with a sticker slapped on it. And if you're not happy or it craps out its Costco so you'll be taken care of.
  3. May 31, 2019 at 12:02 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Costco battery warranty is awesome. You don't need to have it tested. Just bring it in and for another. The only issue is you'll need to remove it in the parking lot or have another car to bring it.
    Optimas reputation from what I read have gone down. I use a Odyssey AGM group 31 but it's much more costly. It just depends on your goals.
    Vlady likes this.
  4. May 31, 2019 at 12:19 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    IMO the majority of batteries nowadays are the same with just different labels. As long as you avoid cheap brands, you’ll be fine. Batteries are a consumable item, so depending on your location, they’ll all last roughly the same amount of time.
    soggyBottom and auskip07 like this.
  5. May 31, 2019 at 8:03 AM
    Lunabird
    Thanks guys, I don’t think I need the extra load capacity yet. Costco batterynit is in the future.
  6. May 31, 2019 at 8:10 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Costco stuff is pretty well vetted before it gets into the store. If I understand correctly, most batteries are made by a handful of manufacturers and sold under multiple labels.
  7. May 31, 2019 at 8:57 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    The Kirkland double As are great they’re made in the same factory as Duracell... oh wait
  8. May 31, 2019 at 9:44 AM
    TinoTaco
    TinoTaco Well-Known Member
    Nanaimo
    2017 TRD DCSB Off-Road - White
    I had 2 yellow top optima's bite the bullet on me in my last car. Had a total of 1000 watts for the stereo and I foolishly never upgraded the alternator so take that into the consideration.
    Honestly if you're close to stock (ie not overlanding etc) the Kirkland battery is going to be just fine for you. Costco's warranty program is pretty hard to beat.
  9. May 31, 2019 at 10:01 AM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
    BTW, there's a northstar GB going on right now...
    shakerhood likes this.
  10. May 31, 2019 at 10:16 AM
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
    I just replaced a couple batteries via Costco. They sell Interstate at my local Costco and are at substantial discount compared to the auto parts stores.
  11. May 31, 2019 at 10:21 AM
    Lunabird
    My commute is really short under 15-20KM a day. I'm wondering if that is killing my longevity of my battery as it isn't getting a good enough charge.
  12. May 31, 2019 at 10:42 AM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    The Kirkland batteries are now made bu interstate and also says so on the batteries. They are good if all you need is a standard replacement battery. Otherwise, there are better batteries at a high price. I went with an AGM, just because i run a dashcam in parking mode and it would run the battery down to a point where at times was too weak to start the truck. I dont have that problem anymore with the AGM.
    aggr0crag likes this.
  13. May 31, 2019 at 6:54 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I have Costco interstate batteries in my S2000, TSX, and Taco. They are inexpensive and have a 3 year warranty. Same batter for our TSX is $85 at Costco and $267 at Northstar. Both have same warranty. Easy choice.
  14. May 31, 2019 at 6:59 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I agree with Scotty, I had a yellowtop Optimas in my tractor >2007 and they failed way early.
  15. May 31, 2019 at 7:12 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    my 16 is over 3 1/2 years old so i decided to get a new battery. took the old one out in costco parking lot put it in a basket, wheeled it in to the battery dept. exchanged for costco battery then installed the new battery in the parking lot. easy peezy, saved me bring back the old one for core refund. if you do this suggest you clean the battery terminals at home first, that's what i did. soak the cable ends in baking soda and water, had to do three or four times to get all the corrosion off. oh yea, make sure you have 10mm wrench to remove the battery
  16. May 31, 2019 at 7:12 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I work with batteries as part of my career. Anyone who thinks an AGM, Gel-type or other high-tech non-spillable battery will outlast or outperform a properly constructed, good quality, flooded-lead acid battery is just wrong. The only advantage to these ghee-whiz colourful batteries is they are non-spillable. Everything else, including lifespan, is a compromise at best.
    t4daddy and mutely like this.
  17. May 31, 2019 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Agree, I promote batteries based on warranty and availability, the king is Interstate (for me in canada), which in turn I have found to be reliable.
    Even the best batteries can fail, and hot climate areas can ruin a fancy battery quickly. I'd rather have an affordable one that I can warranty easy and quickly if it does fail early.
    Where I am around 5 years is time to plan on replacement.
    Stocklocker[QUOTED] and mutely like this.
  18. Nov 15, 2019 at 6:58 PM
    Lunabird
    Just called Costco (Canada) Kirkland doesn’t make batteries that fit a 2017??? Can this be right?
  19. Nov 15, 2019 at 7:18 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    AGM technology is by far the best choice if price isn’t a problem.
  20. Nov 15, 2019 at 7:21 PM
    aggr0crag
    The batteries at the Costco in my area (USA) are Interstate branded.
