KMC Monsters, will they fit?
Discussion in 'Wheels & Tires' started by geerts016, Aug 14, 2008.
  1. Aug 14, 2008 at 3:08 PM
    geerts016
    geerts016 [OP] geerts016
    SLC, UT
    08 TRD SR5 4x4
    alpine 9884 deck, auxilary LED backup lights, alpine 6x9's, alpine 6's, rockford p1000 amp, two rockford p2 10" subs, seat heaters, deezee tool box painted BSP, aero 2525 exhaust, halo projector headlights, LED light strip in hood scoop, black mesh grill, tinted taillights, window visors
    KMC monsters the wheels i want to go with but i'm not sure if the lug pattern will match, does anyone know anything?
  2. Aug 14, 2008 at 3:11 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    6x5.5 lug pattern
  3. Aug 14, 2008 at 3:19 PM
    geerts016
    SLC, UT
    08 TRD SR5 4x4
    so they will fit then?
    thanx
  4. Aug 14, 2008 at 8:10 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    same as 6x139.7 i believe
  5. Aug 14, 2008 at 8:42 PM
    rick
    rick `
    check the backspacing if you are getting bigger tires. unless you want something a little narrower than stock
  6. Aug 14, 2008 at 8:45 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think theyre saying your lug pattern is 6x5.5 or 6x139.7 and if the monsters come in that size then they should fit
  7. Aug 15, 2008 at 6:37 AM
    Anthony
    yup just match the wheels you want to either of those bolt patterns and youre good.
  8. Aug 15, 2008 at 7:51 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    gotta look into backspacing though, depending on tire width so that they wont rub on the UCA's
