KMC XD Enduros help
Discussion in 'Wheels & Tires' started by mikea, Feb 23, 2013.
  1. Feb 23, 2013 at 7:16 AM
    mikea
    mikea [OP] Active Member
    Illinois, west of the Fox
    07 DC TRD SPORT 4x4
    Weather tech, salex center console organizer
    Ok, I purchased some Enduros at Discount Tire and the boys told me that the center caps were to loose when they mounted them. I told them to leave them off but I'd like to have em on if possible, anyone else run in to this issue?
  2. Feb 23, 2013 at 7:19 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I ahd the enduro bead locks but didnt run the center caps. Just rattle can the hub if it looks bad if you cant get the caps to work.
  3. Feb 23, 2013 at 7:29 AM
    double dee
    double dee Well-Known Member
    Arizona
    I never put them on my enduros either. They stuck out to far and looked ugly. Just paint the center black. You can also get the black caps that are on the front wheels from toyota so the back will match.
  4. Feb 23, 2013 at 7:40 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    ^ What they said.
    The center caps on my Methods are loose, too, I actually had one pop off before out in the desert (luckily I caught it).
  5. Feb 23, 2013 at 10:49 AM
    mikea
    07 DC TRD SPORT 4x4
    [I'll try that do you happen to have the part number for the Black Caps
    QUOTE=double dee;6486120]I never put them on my enduros either. They stuck out to far and looked ugly. Just paint the center black. You can also get the black caps that are on the front wheels from toyota so the back will match.[/QUOTE]
  6. Feb 16, 2015 at 12:28 PM
    TacoTuck
    TacoTuck Well-Known Member
    NorthWest
    2001 4x4 TRD SR5
    Leer canopy, OME 881 lift with dakar leaf pack, 265/75/16 duratracs, 16x8 KMC enduros, line-x bedliner and more...
    Sorry for bringing back an old thread but how do the front caps mount onto the back wheels?
  7. Feb 16, 2015 at 9:41 PM
    double dee
    Arizona
    you have to glue them with something. i used jb weld
  8. Feb 17, 2015 at 5:41 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I had those rims on my truck for a bit, I use some plastidip on the hub to make it look perfect.
    The center caps are to long, but you could cut them down with a hack saw and use double sided tape to stick them in.
