KN Cold Air Intake Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTacoProject, Mar 19, 2025.
  1. Mar 19, 2025 at 10:09 AM
    TheTacoProject
    TheTacoProject [OP] Active Member
    New York
    2023 SR5 Tacoma
    So i've been looking to add a CAI to my taco. Issue is deciding which variant. Of the 4 options KN has for the 2023 Tacoma 3.5L, I wanted advice as to which to lean towards. They all seem a bit different but only in slight comparison. 2 are poly urethane manifold tubes one with oil the other is a dry filter. Then the other 2 options are both a dry and oil filter except with an aluminum piping. Just wanted to ask for any first hand experience on them and which I should lean towards. I live in new york, use my taco as my commuter and daily driver, so pls take that into account i'm racking 20K miles roughly per year or more on my truck. So I want the best long term but also will add a good noise. Looking to stay with KN, so just want any anecdotal experiences with the CAI's and which might be best fit for me between an oil or dry filter. Also have seen a lot of threads about oil filters contaminating the engine or MAF sensor. Not sure which way to lean considering. Thanks!
  2. Mar 19, 2025 at 10:15 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    If you want noise, I'd go for some aftermarket exhaust instead of messing with your truck's intake. It's already a cold air intake. And yeah, I'd stay away from an oiled filter on a modern rig.
    Barsoom, Mully, Jakerou and 3 others like this.
  3. Mar 19, 2025 at 10:21 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    They really won't do much for performance but you may get a little more intake noise.
    If you do get one I'd get the dry filters. No oil to mess with. Just spray with cleaner, rinse them and then let it dry out.
    Jakerou and musicisevil like this.
  4. Mar 19, 2025 at 10:40 AM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Overall intake is mostly just for a small bit of noise and whatever you thinks looks best under the hood. And if it's mainly noise than an exhaust will be much more noticeable.
    Oiled filters work fine but you really do need to be sure to properly clean them out and reoil them correctly to make sure they work properly and oil doesn't get on the MAF or other airflow parts. I run one but I also change it out to a dry filter when going into dusty areas (oiled filters dirty up fast when exposed to lots of dust even compared to dry filters), and I generally wouldn't recommend using an oiled unless you specifically have a reason to because of the extra maintenance/cleaning.
  5. Mar 19, 2025 at 10:48 AM
    MGMDesertTaco
    I ditched the k&n drop in filter and went back to the paper oem version. Less mess to deal with and the oem actually filters whereas the k&n lets too much debris in.
    The stock intake with the TRD catback works just fine and sounds great imo.
    Veet-88, usmc2msu and musicisevil like this.
  6. Mar 19, 2025 at 10:56 AM
    TheTacoProject
    New York
    2023 SR5 Tacoma
    For everyone mentioning an exhaust I have an MBRP Exhaust already installed, was looking to add a bit of extra engine noise or performance. Seeing you guys are saying it won't do much for that, if that's the case is it even worth it? Any other mods or additions around the 400-500 range I could add to possibly add a bit to the truck either performance or sound wise to compliment the exhaust? Mostly was looking for that cool whir from the CAI on the engine but could look for other solutions.
  7. Mar 19, 2025 at 11:00 AM
    TheTacoProject
    New York
    2023 SR5 Tacoma
    Also wanted to thank you guys for the replies, def helps. I usually consult my one buddy who works on trucks but he recommended the oil filter because he's never heard of a blocked MAF sensor but i've seen enough threads on here to know it's a lingering problem for few.
    musicisevil likes this.
  8. Mar 19, 2025 at 11:00 AM
    Bishop84
    Bishop84 Well-Known Member
  9. Mar 19, 2025 at 12:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    None of them!
    1. The 3rd Gen Tacoma uses the same air filter that the V8 Tundra in an enclosed cold air intake box.
    2. None of the K&N intakes have an enclosed air box therefore you will have under hood heated air going into the engine which is much less efficient.
    3. Quality aftermarket enclosed cold air intakes are , S&B, Toyota TRD in no order.
    MagicToolbox and Barsoom like this.
  10. Mar 19, 2025 at 12:31 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Like everyone else has said, most CAI's for this truck are worse than stock for performance. I opted to clean up the bay with the K&N JR + the TRD Accelerator. With that installed, the truck for sure shifts smoother and has better throttle response, but any power or mpg increase is negligible. I don't hate K&N filters like some of the other users do, but whatever you choose to do should be fine so long as it keeps an airbox. The stock setup is not power-restrictive at all.
    My post: https://www.tacomaworld.com/threads/drizzohs-21-off-road-build.748190/page-6#post-27527360
  11. Mar 19, 2025 at 1:09 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    You'd have to buy the filter, maintain it, and pay me by the mile to use an oiled cotton gauze filter..
  12. Mar 19, 2025 at 1:13 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    MagicToolbox likes this.
  13. Mar 19, 2025 at 1:26 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I have been on Toyota oiled filter for 40k miles or so. My MAF sensor readings on paper and oiled are the same.
    Use common sense.
    eurowner, Phlogiston and drizzoh like this.
  14. Mar 19, 2025 at 5:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Dirt bikes: oiled foam air filter
    Boats: no air filter at all
    I’m guessing a standard mass produced paper air filter is optimal for mall crawlers. Don’t overthink it.
    Chew and eurowner like this.
  15. Mar 19, 2025 at 11:01 PM
    TheTacoProject
    New York
    2023 SR5 Tacoma
    Based off what i'm getting in response from everyone im thinking im gonna steer away from KN, maybe go with an AFE or S&B (leaning towards S&B due to better overall experience and reviews from most people) and sticking to a dry filter (less hassle) I take care of my truck myself and do all the handy work so replacing a dry filter is much simple them the oil element which seems overkill for my New York environment anyways. Thanks for the feedback from everyone, main reason moving away from stock is the couple this with my MBRP cat back exhaust for a better sound. I'd be fine running stock if it didn't muffle the sound so much.
  16. Mar 19, 2025 at 11:03 PM
    TheTacoProject
    New York
    2023 SR5 Tacoma
    Mostly speaking, it's personal preference, I just needed to know which direction to go with that preference. Most people won't get it, but to me the tacoma stock (especially the SR5 which is my trim) sounds like a fucking camry..... and the exhaust was great but after breaking it in for about 5K miles i really want to add a little something and this was my route best suited.
  17. Mar 20, 2025 at 12:18 AM
    StreetSr5
    StreetSr5 Well-Known Member
    Go with s&b/afe if you want the nice aggressive sound and a closed system! Like the other guy said kn isn’t fully sealed up and is more likely to intake hot air. And +1 for dry filters, not only do they prevent Maf contamination but they also filter better than oiled filters at the slight cost of airflow. Just keep in mind for s&b the dry filter isn’t cleanable and it cost like 60 dollars to replace, I’m not sure abt afe
  18. Mar 20, 2025 at 2:45 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    OP you want more power? Get a tune!
    usmc2msu and Murd3rd like this.
  19. Mar 20, 2025 at 2:56 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
  20. Mar 20, 2025 at 3:00 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    K&N's sound cool. Better filtration? Been de-bunked long ago.
