Knock in steering column
Discussion in '4 Cylinder' started by dgjones, Jun 26, 2009.
  1. Jun 26, 2009 at 11:52 AM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    I have what seems like a slight knock in the steering column of my 09 Taco 2.7. When I drive over a bumpy surface like a gravel driveway I feel a knocking through the steering wheel. I assume this could be a bad steering column because I had the same symptoms with my crappy cobalt and the steering column was the culprit. Any help would be great!!
    Thanks
    David J.
    Portage IN.
  2. Jun 26, 2009 at 11:54 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Since it is an 09, I would suggest having a tech at the dealership drive it. It should be a warranty issue if anything is wrong.
  3. Jun 26, 2009 at 11:57 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I have the same thing, from what I understand this is normal. :notsure:
  4. Jun 26, 2009 at 11:58 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Same here. It also happened in my Ford Ranger, though that's no means of comparison.
  5. Jun 26, 2009 at 12:48 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    mine doesn't knock at all so no it's not normal...go get it looked at under warranty just to be sure
  6. Jun 26, 2009 at 12:59 PM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    I'm having my 09 Offroad TRD looked at for the stearing column. Will update next week to see what they find. My 94 SR5 knocked also.
  7. Jun 26, 2009 at 1:42 PM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    ok so it seems like it could be normal AND a problem I'll check back to see what the tech says about your truck.
    Thanks
  8. Jun 26, 2009 at 1:43 PM
    drew02a
    San Antonio, TX
    So it's a normal problem then? :)
  9. Jun 27, 2009 at 7:56 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I do not have any kind of knock in the steering column of my '09 2.7 reg cab. If I did, it would be back at the dealership getting fixed. Don't let them tell you "It's normal... they all do that" because it's not and they don't.
  10. Jun 29, 2009 at 9:47 AM
    sjdm4211
    sjdm4211 Member
    Tennessee
    Toyota Tacoma 2WD 2.7L
    Its the steering column but mainly the U-joint. If the vehicle is still under waranty have it replaced.
    If it is not under waranty leave it alone. I have been driving mine with a knock in the steering column on rough roads for about a year and a half and it has not gotten any worse.
  11. Jun 29, 2009 at 9:59 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I had that problem to when turning or hitting bumps or any change in incline. The knocking was actually coming from where the spindle mounts to the lower control arm.
    I would reccommend tightening up those two bolts as that might be the problem.
  12. Jun 29, 2009 at 10:12 AM
    TacoBo
    TacoBo Active Member
    North Carolina
    08 4X4 TRD Off Road
    TRD Skid Plate, Tacoma Running Boards, Tuffy Bed Security Lock Box, Spare Tire Lock, Door Sill Protectors, Toyota D-Rings in gthe front of the bed.
    Same here...I was reluctant to have the dealership look at it. The last time I took my truck in for my windows rattling and what I thought to be a transmission issue, they replaced the window seal in the rear with a faulty seal (new one on order) and they rebalanced the tires and scratched my rims with less than 5K on them all to hell. I think I would know the difference between a tire being out of balance and a transmission that shifts down too soon?
    It's untelling what they'd do to my front end if I told them it was knocking. Please keep us posted on what the dealer says.
  13. Jun 29, 2009 at 10:14 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Mine only knocks when I'm off road. On the street it's not an issue , even going over speed bumps.
  14. Jul 13, 2009 at 4:46 PM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    please explain to me where there bolts are
  15. Jul 13, 2009 at 4:52 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Bottom of hub behind the wheel. 2 bolts vertical and parallel to eachother.
  16. Jul 13, 2009 at 5:10 PM
    freesample
    and you tightened them and that was effective? and i may need a pic of them lol
  17. Jul 14, 2009 at 5:26 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    09 4cyl access cab auto
    I'm not having that issue.
    Certainly worth a trip to the dealer.
    Hopefully yours has decent techs there.
  18. Jul 14, 2009 at 10:58 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    WOW,
    If I had an '09 with noise..the service director would know me on a 1st name basis....not nasty BUT I did just PAY$$ for a new TOYOTA....
    It "Hurts" to see some of these dealers trying to "get by" service......I might need to send thank you cards to my service writer and tech's at Dube ;):rolleyes:...
    Scratched wheels or poor service NEEDS to be FIXED,if not with service director, a walk out to the sales department ( you never want a PO'd customer on the floor during sales;) ) to see the sales manager,quietly ask for help.AMAZING how much "Honey" can get you while being a jerk just gets same:cool::cool:......
    Keep us updated on your "knock" and I'm going to inquire up here in Yankee town....see if it is nation wide..
    Snoope
  19. Jul 14, 2009 at 11:10 AM
    coma09
    BC Canada
    Had snows swapped years ago, and their guys chipped the wheel finish.
    Asked the service manager if he could touch them up.
    Had an appt. a few days later, and they replaced the wheels. Over and above what I was expecting.
    They beat up your wheels, they own the problem.
    Be curious to hear back what the dealership found to be the cause of the knock.
  20. Jul 14, 2009 at 11:32 AM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    just take it back to toyota to check it up... its under warranty so what could it hurt to go get it check...
