Knock in steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tictoc, Dec 7, 2009.
  1. Dec 7, 2009 at 10:40 PM
    tictoc
    tictoc [OP] Active Member
    HAWAII
    FABTECH
    fabtech 6 in,33 procomp x terrain/micky thompson 17" beadlocks,steering stabilizer kit,k&n 77 series intake with throttle body spacer,ravin exauhst
    i have been having this issue were i can feel and hear knocking in the steering wheel...any ideas on what this could be?? only while offroading
  2. Dec 8, 2009 at 12:19 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    tie rod ends or ball joints. One of the two, doubtful anything else. Sit at a stop and flip your wheel back and forth. If you feel it at a stop, its definitely tie rod ends. If you feel it more when you're going down the road or bumps its likely ball joints.
    You're a 2005, depending on mileage, its getting about that time for them to start wearing out.
  3. Dec 8, 2009 at 12:21 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    6" lift??? if your 4x4 its prolly your cvs
  4. Dec 8, 2009 at 1:19 AM
    brian
    Elizabeth City, NC
    Please explain why you think this, I'm curious. I don't understand how you can feel CV's knocking in your steering wheel when you're going over bumps.
  5. Dec 8, 2009 at 8:17 AM
    Yoytoda
    Roland
    completely stock
    um he didnt say anything about going over bumps. he said offroading. Im just figuring on the street hes fine but when offroading hes throwing it into 4x and then knocking and shaking in the wheel starts when hes wheeling around.
  6. Dec 8, 2009 at 8:19 AM
    Yoytoda
    Roland
    completely stock
    to add to the one comment it could be wheel bearings too. 6" lift with 33s with less than stock backspacing puts alot of wear and tear on the suspension...
  7. Dec 8, 2009 at 8:24 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I actually think it's normal. When I take my truck off road I feel the knocking in the wheel also. It's most likely the intermediate steering shaft that connects the steering column to the rack and pinion. Chevrolet has had a big problem with this. On some of the Silverados you can feel the knocking just turning the steering wheel on the street. My 2004 Chevy had to have the shaft replaced twice. That doesn't mean that the Tacomas have the same problem, but it feels the same to me having driven both trucks.
  8. Dec 8, 2009 at 8:27 AM
    Yoytoda
    Roland
    completely stock
    thats weird all my chevys had a steering box...
    i never had that issue on any of my chevys
  9. Dec 8, 2009 at 9:09 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    On the 1999 - 2007 Silverado, the 4x2s have rack and pinion and the 4x4s have a gear box. However, both use the same intermediate steering shaft. GM originally tried to fix the issue with a lubricant kit, but that did not work, so they replace the shaft instead. I have a shelf full of replacement shafts at the Chevy dealer I work at, but I only brought it up because, when I first took my Tacoma off road, I felt the same kind of knocking in the steering that I felt in my Silverado. Again, I think it is normal on the Tacoma, but I may be wrong.
  10. Dec 8, 2009 at 10:12 AM
    Yoytoda
    Roland
    completely stock
    My tacoma is fine but a 6" lift puts lots of weird stresses on everything
  11. Dec 8, 2009 at 10:28 AM
    brian
    Elizabeth City, NC
    I'm not gonna argue it, maybe you have some experience with this that I don't but I don't agree that it could be cv's or bearings at all. Hopefully he figures it out because now I'm curious.
  12. Dec 8, 2009 at 10:41 AM
    Yoytoda
    Roland
    completely stock
    ive driven lifted trucks my whole life. When you lift something 6" or more you put tons of stains on components. Wheel bearings are designed to hold weight vertically. The stock backspacing is set to keep the center of the tire over the center of the front wheel bearing. When changing backspacing you put the center of the wheel further out, away from the center of the bearing. this adds axial strains causing wheel bearings on IFS to wear really fast. Solid axles have different style wheel bearings making them less sensitive. My chevy used to chew through CVs, wheel bearings, and upper ball joints every 6months.
    I wasnt disagreeing with anyone but adding other things to check
  13. Dec 8, 2009 at 10:43 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Mines's done the same thing since day one.... only while off-roading/rough terrain or hitting a speed bump to fast lol.... The steering itself feels tight, just something with the wheel linkage...
  14. Dec 8, 2009 at 10:50 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I love lifted Chevys. I get to make lots of money selling parts. Especially wheel bearings.:D BTW, good advise.
  15. Dec 8, 2009 at 7:12 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    do toyotas have a splined slip joint where the steering column bolts to the rack?hondas do and when that slip joint gets dry it pops when hitting bumps or turning the wheel.
  16. Dec 8, 2009 at 7:43 PM
    tictoc
    HAWAII
    FABTECH
    thanks 4 the advise ill get them changed ASAP...my lower ball joint is not looking so well
  17. Dec 8, 2009 at 7:46 PM
    tictoc
    HAWAII
    FABTECH
    is there a way to check 4 bad CVs??? and if it were bearings wouldnt there b a different sound other than knocking?
  18. Dec 8, 2009 at 7:53 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    What about the steering rack bushings?
  19. Dec 8, 2009 at 7:55 PM
    Yoytoda
    Roland
    completely stock
    on dry pavement put it in 4hi and crank the wheels all the way one way and drive in a circle if they are real bad they will clunk alot. another way is to take them off and look for play.
  20. Dec 8, 2009 at 8:03 PM
    tictoc
    HAWAII
    FABTECH
    not sure but i will b looking tonight 4 loose bolts i will try n see if i can take a look at the bushings as well...i know 4 a fact that i must change my ball joints ...jus the lowers really but im planning on changing them all... i also found a tear in the tie rod end cover so im asuming its pretty beat up
