Knock Knock, it’s cylinder 3
Discussion in '2nd Gen. Builds (2005-2015)' started by Texoma, Nov 28, 2023.
  1. Jun 12, 2024 at 5:49 AM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you could replace it with another constant tension clamp, that'd be the way to go.
  2. Jun 12, 2024 at 6:07 AM
    #102
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Those wurth hose clamps are really good if you don't get the constant tension ones.
    Torspd likes this.
  3. Jun 12, 2024 at 6:43 AM
    #103
    Texoma
    Texoma [OP] IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I’ve got the URD big aluminum radiator and the nipple is a little small on it, so I blame that.
  4. Jun 12, 2024 at 9:56 AM
    #104
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Is that a throttle body spacer from URD? Or some adapter? What does it do?
  5. Jun 12, 2024 at 10:42 AM
    #105
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    65mm to 76mm TB adapter
  6. Jun 12, 2024 at 11:14 AM
    #106
    TireFire
    Olympic Peninsula
    On an N/A motor? Pourquoi?
  7. Jun 12, 2024 at 1:33 PM
    #107
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yeah, I don’t think it does a whole lot, but I got the TB for almost free.
  8. Jun 12, 2024 at 2:36 PM
    #108
    TireFire
    Olympic Peninsula
    According to JustDSM’s testing the 70mm one from the 5G T4R does add a little power but 76mm probably does not since it’s way larger than the plenum opening
  9. Jun 13, 2024 at 5:21 AM
    #109
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Once I get the 2nd oil change done, drop the oil pan n clean it, run 2 tanks of premium, I’m going to start playing with the tune on this and see what I can pull out of it. First oil change last night looked good. Even though the oil only had 40 miles on it, it was already darker than normal, not like 5k oil change, but a few shades darker than fresh. 2nd oil change I’ll run some seafoam in the crank case to really clean it out. Then should be good after that. Probably also clean the VVT filters as well. Also found the mousekawitz’s had made a nice little home on top my cabin air filter and clogged the condensate drain. Unfortunately I had to evict them, but they’ll find a nice home at my work somewhere.
    Rodarbal and Torspd like this.
  10. Jun 14, 2024 at 3:43 AM
    #110
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol.
  11. Jun 16, 2024 at 5:32 AM
    #111
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Maiden voyage out to Hidden Falls, on 3’s it just walked right over everything. First 4 I took it on, CV axle broke. Swapped it out, then next trail was another 4, broke a ujoint. Power train was strong though.
    Rodarbal, Torspd and MY50cal like this.
  12. Jun 17, 2024 at 3:58 AM
    #112
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Power train is no longer the weak link. Lol
    thomasburk likes this.
