Knock sensor- Circiut Low questions
Discussion in 'Technical Chat' started by toyotaT32, Dec 24, 2011.
  1. Dec 24, 2011 at 11:14 AM
    toyotaT32
    toyotaT32 [OP] Well-Known Member
    Thomas
    Palmer, Alaska
    3 inch revtek in coil spacer, all pro bumper, smittybuilt 8000 winch, 265/75/17 BFG AT, cookie monster stuffed animal in bumper... UPDATE 10/17/12.... OME886 Coil lift with spacer. UPDATE 9/6/13..... Plasti dipped 17inch eagle alloy wheels. 285/70/17 Goodyear Duratracs, 6 bulb rigid industries LED D2 lights
    OK, so I read up a little bit on the forums here and got some good info on where they are located and what the possiblility of problems might be. I honestly dont know how much the dealer will charge for replacing or fixing the problem, nor do I have to tools to fix it myself. I am about to drive 3900 miles in a week and a half. Tennessee back to Alaska.
    So what I am wondering is what could happen if I dont replace it and drive that far?
    I dont want to break down and be stranded in Canada in subzero temp...
    Any info or tips will be greatly appreciated.. Thank you.
  2. Dec 24, 2011 at 11:15 AM
    toyotaT32
    Thomas
    Palmer, Alaska
    The system check said...
    Knock Sensor 2 Circiut low code P0332
  3. Dec 24, 2011 at 11:25 AM
    MadTaco461
    MadTaco461 BRO runner
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
  4. Dec 24, 2011 at 1:38 PM
    toyotaT32
    Thomas
    Palmer, Alaska
    Classic Gir man!!! Nice truck too...
    I appreciate the info and that website link. I just got back from the store and the check engine light went off. So my guess is its a loose wire.. But Ill have to look at it to determine it.
    Thanks Again
