Knock sensor detecting knoks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 6, 2014.
  1. Feb 6, 2014 at 12:31 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    What exactly is a knock? Is it bad for your engine and if it is, how do I fix it? Thanks.
  2. Feb 6, 2014 at 12:39 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Check spark plugs? Try mid-grade fuel? Pinging is bad and can damage the cylinder over time.
  3. Feb 6, 2014 at 1:06 PM
    1tacoplease
    Temecula
    Don't really know how to check spark plugs and I've been running 91 octane since I got it. Isn't it bad to go to a lower octane if I've always been running 91?
  4. Feb 6, 2014 at 5:20 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    What's the code?
  5. Feb 6, 2014 at 5:35 PM
    1tacoplease
    Temecula
    My CEL isn't on, so I have no code. I bought and OBD2 scanner and I got a knock detector app. I ran it and it said I had several knocks at different RPM points. Is this bad, normal, or should I do something about it. I don't really hear anything from the engine. I am running an intake, headers, exhaust, and TBS.
  6. Feb 6, 2014 at 5:44 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    How many miles since you changed the plugs? or how many miles are on the truck now?
  7. Feb 6, 2014 at 5:47 PM
    1tacoplease
    Temecula
    I have less than 50,000 miles on the truck and I think I replaced them at 30,000 if that is what the dealer recommended but I can't remember.
  8. Feb 6, 2014 at 5:48 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    An engine knocking can be caused by several reasons. Bad spark timing, bad plugs and coils, bad fuel, lean condition in the cylinder. Could also be a lot a carbon buildup that is causing a hot spot. I ran seafoam through my truck and let it sit for a few hours. You would not believe the chunks of carbon that came out of my tailpipe. I also don't know if you need to run 91 octane? I know they needs it in 2005 but I thought they changed that. You can swap from 91 to 87 no problem as long as your engine doesn't require 91
  9. Feb 6, 2014 at 6:09 PM
    1tacoplease
    Temecula
    My engine doesn't require 91 but I thought it was a good idea to run it to keep the longevity of the engine. I heard you get better gas mileage and run a cleaner engine with less gunk. Am I wrong in thinking this? So, I should run sea foam to try and fix the problem? I believe my engine could be running lean because of all the mods I did but I'm not getting a CEL. I'm planning on buying the URD maf calibrator to even the air fuel ratio. What are your suggestions?
  10. Feb 6, 2014 at 6:16 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    what is the problem....
  11. Feb 6, 2014 at 7:15 PM
    smmarine
    Melbourne FL
    All the 91 octane does is resist detonation for a higher compression ratio. It won't do anything for a stock engine as far as more hp, better economy, etc. I doubt you need 91. Your probably just wasting money. And your ECU should be able to recalibrate the a/f mixture for your mods. With less then 50k miles you shouldn't have any carbon buildup. On my 60k nissan the tops of the pistons were still silver. My taco has almost 160k. So I have carbon buildup As far as your problem, if there is no CEL then I don't see how your knocking. The engine would pick it up and throw a code, flipping the CEL. I'm thinking the app your running is saying something that is not actually happening. If your really worried, go to the dealer and tell them your problem. Ask if they would do a test with their scanner to confirm. Most should free of charge.
  12. Feb 6, 2014 at 7:21 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Stop running 91... It may not fix the knock but it's literally a waste of money. Unless your running higher than stock compression there's no reason for it. It does nothing to help the engine, that's a common misconception.
  13. Feb 6, 2014 at 7:27 PM
    smmarine
    Melbourne FL
    ^again what he said. I hear it all the time. Some people do after many miles because of the carbon buildup. It creates hotspots on the pistons that detonate the fuel early. You should not have this problem
  14. Feb 6, 2014 at 7:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My POS '12 has knocked from day one as well, regardless of what gas I used. So I am back down to 87 because I basically don't give a damn about the octane rating. Lol.
  15. Feb 6, 2014 at 7:55 PM
    1tacoplease
    Temecula
    I've read the octane thread and a lot of credible memebers, like chris4x4, say running 91 octane improves performance and mileage. I just thought since ai have some performance mods, I should run the higher octane to even things out. I'm skeptical about going down to 87 unless it will fix my knock. My main purpose of using 91 octane was to preserve the engine life because I plan on keeping my truck for a long time. I'm very happy with my truck but always looking for more performance upgrades. The knock and what you all have posted kind of scares me now. I don't want to do damage to my engine but I do want performance gains.
  16. Feb 6, 2014 at 7:56 PM
    smmarine
    Melbourne FL
    It just means your one step closer to a diesel haha
  17. Feb 6, 2014 at 7:59 PM
    smmarine
    Melbourne FL
    It improves performance and mileage if you have done something to change your compression ratio. Otherwise it's not doing anything. If it was that easy to get more power and mpg I would be running race fuel haha
  18. Feb 6, 2014 at 8:13 PM
    1tacoplease
    Temecula
    I have not done anything to my compression ratio yet... What will fix my, alleged knock, from my knock sensor reading off an OBD2?
  19. Feb 6, 2014 at 8:37 PM
    timmytoast
    timmytoast Card-Carrying Illuminati Member
    Prison City, CA
    2013 SR5 4x4
    Black Plastiderp Front Emblem and Grille Surround, Relocated Horns, Bed Mat w/ bolt mod, Precision Fit seat covers, Anytime Fog Light Mod, Console and Glove Box Organizers, DIY Washable Cabin Air Filter, Pop N Lock Tailgate Latch, K B Voodoo Bed Brackets
    Read the Owner Manual. Some knocking is completely normal according to Toyota. Depends under what RPM/driving conditions it's occurring. It's usually under accelerating onto the freeway and when the truck is "under load".
  20. Feb 6, 2014 at 8:50 PM
    1tacoplease
    Temecula
    That is exactly when I got the knocking. So, leave it be or try the sea foam? And, can I stay 91 octane, or is that bad?
