knock sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by scottyp, Dec 16, 2008.
  1. Dec 16, 2008 at 6:46 PM
    scottyp
    scottyp [OP] Member
    98 tacoma
    i have 1998 3.4 v6 cel say's knock sensor was going to try and change the pigtil frist does anyone have any thing to add never change one before?????
  2. Dec 16, 2008 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What code are you getting from the CEL?
  3. Dec 16, 2008 at 6:52 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    the knock sensor(s) are normally open circuits. so you'd have to have a short in the pigtails or the wiring between them and the ecm to have that be the problem.
    have you heard / felt a lot of pre-ignition going on?
  4. Dec 16, 2008 at 6:55 PM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    The pig tails get brittle from all the heat. That would be my guess. I have only see them go bad if someone has been in there before, like if the headgaskets were done. If you have to put sensors in make sure you tighten them to the correct spec. You dont want to over tighten them..
  5. Dec 16, 2008 at 7:04 PM
    scottyp
    scottyp [OP] Member
    98 tacoma
    code p0325
  6. Dec 16, 2008 at 7:07 PM
    scottyp
    scottyp [OP] Member
    98 tacoma
    is this under the air plantum? how hard would it be to change
  7. Dec 16, 2008 at 7:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Dec 16, 2008 at 10:41 PM
    scottyp
    scottyp [OP] Member
    98 tacoma
    thanks for the help
