knock sensors
Discussion in 'General Automotive' started by bretts, Oct 17, 2019.
  1. Oct 17, 2019 at 5:13 PM
    bretts
    bretts [OP] Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    I picked up some really suspect knock sensors off Amazon for my lexus es300 and was wondering if I can connect them to the vehicle without installing them to make sure they actually work.
    I got both knock sensor codes and assumed the wiring harness was bad, so broke it all down and replaced the wiring and put it all back together... and now I still have a P0330 knock sensor code. So I guess one of the sensors actually WAS bad and I made a terrible assumption.
    The good? I can probably tear it apart and put it back together in less than 3 hours without breaking anything this time... The bad? I bought both sensors on amazon for $27 and I'm scared to install them... Especially after seeing the packaging... Surely these aren't OEM Toyota "CLOCK" sensors.
  2. Oct 18, 2019 at 1:08 PM
    bretts
    Pasadena, TX
    got them installed in under 2 hours and all seems well... got overdrive back and no more CEL so far.
    Update 8/2022: still working fine amazingly!
    Lumberjackcoma likes this.
