Knocking after strut replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyjeep, Sep 25, 2010.
  1. Sep 25, 2010 at 5:23 PM
    Toyjeep
    Toyjeep [OP] Member
    Mitch
    Denver, CO
    2003 TRD Tacoma
    Supercharger, 3" lift
    Yesterday I replaced my tokico front struts with bilstein 5100's on my 2003 tacoma. The install was pretty simple, and rides much better now, but I hope this is not a fluke. I have been hearing a knocking sound on the passenger side when I turn at different speeds. Is this typical after a strut replacement, is it the struts that are making the knocking sound, or is it something I did when I disconnected then reconnected the sway bar? I only disconnected the sway bar on the passenger side...then reconnected after the strut/spring assembly was in place.
    Other than the knocking, the ride is 100 times better.
  2. Sep 26, 2010 at 8:36 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is the sway bar link loose, on the passenger side. My Honda makes knocking sounds and found that sway bar links were the problem.
  3. Sep 27, 2010 at 7:04 AM
    Toyjeep
    Toyjeep [OP] Member
    Mitch
    Denver, CO
    2003 TRD Tacoma
    I checked the sway bar and links, and everything is tight. Thanks for trying though.
  4. Sep 27, 2010 at 8:08 AM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    did your get the tab lined up when you put the upper strut mount back on.
  5. Sep 27, 2010 at 10:33 AM
    Toyjeep
    Toyjeep [OP] Member
    Mitch
    Denver, CO
    2003 TRD Tacoma
    What do you mean by tab.....I have toytec lift spacers in the front for the upper mount, and everything lined up fine.
  6. Sep 27, 2010 at 10:56 AM
    Pyro
    Pyro Well-Known Member
    Jon
    Tehachapi, CA
    14' Tacoma TRD Offroad
    Bilstein 5100
    a few weeks ago I had a knocking noise from my front end also. It was making the noise because one of my studs broke. I suppose the way you can find out if its your swaybar, then just take it off, and if it still makes the noise then you know its not the sway bar. I just took mine off yesterday.
  7. Sep 27, 2010 at 11:11 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Sway bar is overrated anyway. ;)
    I've had mine off for a while now, and besides a little more lean in the corners, I haven't had any issues. I've even had to do emergency maneuvers to avoid Bambi the other day and never felt it was out of control at any time.
    I actually prefer the ride with out it since now my left and right sides aren't linked quite as much so bumps stay on their own side better.
  8. Sep 27, 2010 at 6:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you remove it completely or just disconnect it? I always figured the bar added some "protection" for the steering rack.
  9. Sep 27, 2010 at 8:22 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Mines completely gone and sitting in the corner of the garage. Originally, I just left it disconnected and zip tied it up out of the way, but I eventually just completely removed it.
    I do have a bud built skid plate that well covers the steering, but never really thought about the sway bar as protecting anything since its so close to the underbody and would take quite the odd scenario for it to offer protection.
  10. Sep 27, 2010 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you got the 3 pieces of bud built skids, you certainly don't need any added protection the sway bar might offer. :eek:
    I've been considering those BB skids. Do they come unpainted raw metal?
