Knocking front left tire area
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shane.77, Oct 9, 2019.
  1. Oct 9, 2019 at 10:12 AM
    Shane.77
    Shane.77 [OP] Member
    Shane
    2018 Toyota tacoma TRD sport
    I have a 2018 Trd sport 4x4. I had knocking going on in my front left tire area I took my truck to the dealership and they said its normal wear. I told them it never made this sound ever sense I got the truck. Has anybody have the same issue... also I called corporate they want me to get a second opinion from a different dealership
  2. Oct 9, 2019 at 10:40 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Brake pads moving in caliper. Others have had this issue.
  3. Oct 9, 2019 at 10:42 AM
    Shane.77
    Shane
    It only happens when I go over bumps
  4. Oct 9, 2019 at 10:44 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Is it stock?
  5. Oct 9, 2019 at 10:49 AM
    Shane.77
    Shane
    Yes
  6. Oct 9, 2019 at 10:51 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    did they check the cab mount?
  7. Oct 9, 2019 at 10:51 AM
    Shane.77
    Shane
    Probably not
  8. Oct 9, 2019 at 11:02 AM
    GreyBaldTaco
    2019 F150 5.0
    It's been an issue for others. May want to have them check.
    Shane.77[QUOTED][OP] likes this.
  9. Oct 9, 2019 at 11:44 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I had this issue, but it was only when I drove on snow covered roads and the temp dropped below 10 degrees. Turned out snow was packing between the frame and the body, then freezing solid. When I hit bumps the frame and body moved and made loud banging sounds.
  10. Oct 9, 2019 at 11:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Check and make sure the sway bar end link is tight. Dunno why it’d be loose but that would cause a knock over bumps. Just need a 17mm and two seconds of your time.
