Knocking inside cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ethansawicki, Aug 11, 2013.
  1. Aug 11, 2013 at 6:08 AM
    Ethansawicki
    Ethansawicki [OP] New Member
    08 prerunner
    Ok so I changed my plugs and my oil and it started to knock this morning inside the cab. Used denso platinum plugs cause they were 2.99 and advance auto could that be the problem? It seems like the plugs after I changed them it amplified the tacoma tick but wasn't too sure. Anyone have any ideas?
  2. Aug 11, 2013 at 7:52 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    4.0 or 2.7? (Don't recall if the PreRunner ever comes with the 2.7, sorry).
    For the 4.0, use only copper plugs (I get them from the dealer, even there they don't rape you too bad.) The concensus is that platinum plugs + 4.0 = problems.
    Is this "knock" you hear at idle, or under load (accelerating, driving uphill)? If it's the latter two, it could be spark knock. I'd pull the plugs and swap them with an equivalent copper plug (even if not from the dealer, at least get copper plugs from the local parts store).
    Any chance you underfilled the oil or swapped in the wrong weight oil? Oil light coming on or staying on longer than usual (more than 1-2 seconds) when you start the truck?
  3. Aug 11, 2013 at 8:04 AM
    Ethansawicki
    08 prerunner
    Yeah it's the 4.0 the normal tacoma tick it seemed like it amplified after the platinum plugs were put in. I put 5 qts of 5w30 havoline me brand didn't change the filter though
  4. Aug 11, 2013 at 8:22 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Thats like taking a shower and putting the same skidmarked undewear back on.
