Knocking issues?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nickykabob, Feb 5, 2023.
  1. Feb 5, 2023 at 1:05 AM
    nickykabob
    nickykabob [OP] #P0136
    Columbus, Ohio
    2003 Black DCSB SR5 TRD S/C V6 140k+ Miles
    Wish my GPA was as high as the gas prices.
    Just a little backstory on this engine, both knock sensors on this were bypassed less than 2 years ago. This engine does not have and kind of tuning or fuel mods to support the s/c, simply was bolted on when I received it roughly 4-5 years ago.
    In the past few months this truck has sat mostly stationary though has been started and moved frequently. This seems like only a recent problem and my assumption is that it comes down to the inevitable issues that come from not properly modding this engine. The shop that also fixed the sensor issues also explained to me that the fix was merely temporary and there was a chance future issues might occur.
    What I’m curious about now is the source of this noise, I’ve linked a video to it. It’s only really audible at low rpms.
    https://youtu.be/eZ1TaoxMlvM
    1997tacomav6 likes this.
  2. Feb 5, 2023 at 1:15 AM
    tcjacado
    tcjacado Well-Known Member
  3. Feb 5, 2023 at 8:52 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Sort of sounds localized up top in that area. Any plastics vibrating against something? Doesn’t really sound like knock to me.
  4. Feb 5, 2023 at 9:36 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    When was the last time the blower was serviced? Might be the blower
    tcjacado likes this.
  5. Feb 5, 2023 at 9:44 AM
    1997tacomav6
    Denver
    Sounds like the supercharger to me,
    Probably not knock sensors
    Take the belt off the supercharger so it's not spinning and run it for just 30 seconds and report back
  6. Feb 5, 2023 at 9:44 AM
    nickykabob
    Columbus, Ohio
    I honestly do not know. Is there a thread relating to maintenance on them?
  7. Feb 5, 2023 at 9:47 AM
    nickykabob
    Columbus, Ohio
    I agree, it does sound located up and to the right side, as far as I can see there’s nothing loose in there. As others have suggested it might be the blower.
  8. Feb 5, 2023 at 9:50 AM
    1997tacomav6
    Denver
    Or take a stethoscope and put it on rotor pack area or nose snout section
  9. Feb 5, 2023 at 4:32 PM
    nickykabob
    Columbus, Ohio
    You'd be correct, the sound wasn't audible after taking off the belt. Definitely coming from the blower.
    1997tacomav6[QUOTED] likes this.
  10. Feb 5, 2023 at 4:41 PM
    1997tacomav6
    Denver
    Time for a full rebuild from Jon Bond!
    Don't drive it, you can do more damage that will cost u more
    Did you ever check the snout oil level?
    Your rotor pack seals can leak oil out of the snout into the supercharger and run dry and you will never know it till its to late if u don't check
  11. Feb 5, 2023 at 5:09 PM
    nickykabob
    Columbus, Ohio
    I have not. If I can I will check. Looks like it's time to start saving.
