Knocking noise. Starting to scare me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedoJosh, Apr 12, 2015.
  1. Apr 12, 2015 at 11:36 AM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So I have an occasional knocking noise coming from the truck, and I believe it's the engine. I say occasional b/c it's not constant, but it's very frequent.
    Most of the time it happens when I'm in too high of a gear for the speed or situation. So for example, cruising at 35 and going up a hill. Instead of mashing the gas to prevent speed lose, I'll just keep the same throttle. Nearing the top of the hill there is a very noticeable knocking noise. Not a high pitch, but a deeper noise. Once I let off the gas it stops.
    Also, can make it happen if I'm cruising in traffic slowly when the RPMs are low(around 35-40), and then give it a good bit of gas (but not floor it to cause an instant gear change.). Before the truck down shifts, there is a noticeable knock.
    Truck is a 2010, 130k miles. Dealer maintained it's entire life. With the stereo on, I can't hear it. I would almost swear this never happened before I had the transmission serviced at the dealer 10k miles ago, but could be a coincidence.
    Any thoughts? I've heard that these engines are noisy buggers, and of spark knock. I'm not exactly sure what spark knock sounds like, so hard for me to write it off as such.
  2. Apr 12, 2015 at 11:47 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    I'm gonna go with a wild shot here and say it could be an engine mount is loose. Granted noises can be one half a million or another until someone can eyeball it. I say an engine mount because stop and go traffic and normal wear and tear could lead to the mount failing. And in most engines they are mounted resting on a rubber bumper. Naturally this rubber bumper doesn't last forever and its purpose is to allow a slight give when the engine is under torque. Similar torque to what you have described. Good luck! Its a start at least!
  3. Apr 12, 2015 at 12:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Have you greased the driveshaft u-joints and checked the center bearing for excessive play, lately or ever? [​IMG]
    scottalot and File IFR like this.
  4. Apr 12, 2015 at 12:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's from lugging the engine, it's rod knock.
    You gave a perfect description of both the technique that causes it and the sound.
    If it were manual, you'd be driving it incorrectly, needing to downshift, because just as you say 'it happens when I'm in too high of a gear for the speed or situation'.
    In the short term, either manually downshift or give enough gas to make it downshift. Manual downshift would be what I'd do.
    In the longer term, I'd see if the trans needs adjustment. Sounds like it's out of sync with when it should downshift. Forum member gearcruncher may have some input on this topic for us.............
    Does it ever seem to hang on the upshifts? Like take too long? Over rev during the shift?
  5. Apr 12, 2015 at 12:53 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Clearwater Bill has it right.
  6. Apr 12, 2015 at 5:53 PM
    SpeedoJosh
    Florida
    The only time I really notice a high rev issue is when I roll out of parking lot that is on a hill and I'm heading down the hill. When I give it gas it will high rev, like the truck is in neutral. To avoid this, I can give it more pedal before I roll out and it will shift to second before momentum is carrying the truck down the hill.
    Think they messed up the trans service at the dealer, and that's causing the issue? Maybe too low of fluid?
    Rod knock sounds like a bad thing. Is my engine doomed in the next 10k miles or am I ok?
    As far as maintenance, this thing has been taken to the dealer every 4-5k miles since new. All required maintenance was done by them, so it should be up to date on everything. But, to answer your question, No, I have not personally checked for play or greased anything.
  7. Apr 12, 2015 at 5:58 PM
    SpeedoJosh
    Florida
    One more thing. Sometimes the noise sounds a little different. Knocking to an extent, but almost with a gurgle/rattle noise to it, if that makes any sense.
  8. Apr 12, 2015 at 6:05 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Could be spark knock try a tank of premium fuel see if it goes away. If it does it's probably caused by carbon build up. give it a shot of "sea foam" or equivalent then run the s%$t out of it for a few miles to clean it out
  9. Apr 12, 2015 at 10:01 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    My first thought cause it only happens at low rpm's,
    just for shits & giggles unbolt the air box on the pass. fender,, you'll see the air horn that goes thru the fender with foam tape on it that's probally compressed allowing the plastic to hit the fender which will cause a vibration.
    Can't hurt and it only takes about 10min to take off and go for a ride.
  10. Apr 12, 2015 at 10:05 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I can tell you my experience.. I had the exact same noise a few weeks ago after a trip. Scared to death my trans or engine was gone. Turned out to be the stock air box popping around took 10 minutes to fix check make sure everything is tightened down and check where it goes into the fender.
  11. Apr 17, 2015 at 5:03 AM
    ranger71
    ranger71 Member
    Knoxville, TN
    2012 SR5
    I have exactly the same issue with my 2012 Tacoma with only 42k miles. It has been going on for about a year. At first I thought it was just a bad batch of gas. After it continued I started using mid grade fuel and then premium. Running premium gas seems to pretty much eliminate the knock, but I shouldn't have to spend the $$ for premium gas when the engine is made to run on regular. At my last service I mentioned it to the Toyota Service writer and he said to try injector cleaner. So far injector cleaner has done nothing. I am still looking for a solution.
  12. Apr 17, 2015 at 5:16 AM
    Brandon9281
    Brandon9281 Member
    Indiana
    2013 TRD Off Road double cab
    Softtopper, wet okole,
    Ranger71, Read this thread http://www.tacomaworld.com/forum/2n...14-feedback-engine-ecm-reprogram-pinging.html
    On page five I posted a video of the sound people are hearing. The TSB has fixed this in my truck. It took less then 30 min to flash the firmware and completely stop this noise. plus it made my truck and many others run smoother.
  13. Apr 17, 2015 at 5:54 AM
    Alament92
    Alament92 Well-Known Member
    Austin
    Arizona
    2012 Tacoma TRD Sport
    HID's, Rancho quicklift, 295/75/16 Nitto Terra Grapplers, Method Race Wheels, K&N CAI, LED interior dome, map, license plate lights, 30 inch Avec LED light bar, Anti-dark hood lighting kit
    I think I may have the same noise in my. Truck.. Almost sounds like a crackling noise while accelerating
  14. Apr 17, 2015 at 6:06 AM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    ^^^^This! I had the same issue. Dealer flashed with the TSB fix and I was all fixed.
  15. Apr 17, 2015 at 6:33 AM
    Alament92
    Austin
    Arizona
    What the heck does tsb stand for. I see thiseverywhere
  16. Apr 17, 2015 at 7:35 AM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    Means technical service bulletin. They aren't recalls, but Toyota is acknowledging that it is a known problem.
  17. Apr 17, 2015 at 8:23 AM
    Alament92
    Austin
    Arizona
    Thanks!
  18. Apr 17, 2015 at 10:04 AM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I have been experiencing the similar knocking sound, though I cant pin point if it's from the engine or the driveline below. It comes and goes quickly and not easily duplicated. I'll strap a GoPro in the engine bay and under the truck to try to record this. My guess is the slip yoke needing a regrease.
  19. Apr 17, 2015 at 1:46 PM
    pgwveteran9091
    pgwveteran9091 Member
    Fort Mill,SC
    2015 TACO
    I had the same thing happen with my Ford Sport Trac..about 20K later the engine ate a rod and engine seized. It started with MAF sensor out of whack. I later found out it was a design flaw in the engine and Ford decided to go engine experimenting. Hence, now a proud TACO owner =) YEAH!!
  20. Jun 4, 2015 at 5:28 PM
    Metzbower
    Metzbower Well-Known Member
    Winston-Salem, NC
    2014 Tacoma 4WD long bed
    Just had my '14 reprogrammed and noise is gone. I lived with it for 35k miles. Averaging 22 mpg too, far better than my 07 4Runner.
