Knocking noise
Discussion in 'Long Travel Suspension' started by FixedTRD, Mar 16, 2011.
  1. Mar 16, 2011 at 12:29 AM
    FixedTRD
    FixedTRD [OP] Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Ok I just installed my All pro kit about 2 weeks ago. I got this kit used and was told it only had about 10k on it. This weekend I hear some grinding and knocking from the left side. It seems like when going under 10mph and going over bumps or my drive way it knocks and some grinding noise. But when its over 25mph its fine I don't hear anything. I have a prerunner if that helps. I was thinking it might be rack and pinion. But it has the All pro longer control arms and it looks fine. Anyone have this issue? I'm thinking about taking the shock to get them refilled to 150psi to see if that helps. I don't see any leaks or any fluid leaking from the shocks. Thanks guys.
  2. Mar 16, 2011 at 8:25 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    race truck parts make race truck noises... but you should still check all your bolts. after 2 weeks you might need to retorque something
    stuff makes tons of noise, could be your bushings or your heims... and thats normal.
    no leaks are good. check the uniballs, if they have any play in them they need to be replaced.
    dont worry, my truck sounds like it's about to fall appart. but it never does... except for that one time haha
  3. Mar 16, 2011 at 8:49 AM
    FixedTRD
    Will
    Alhambra, CA
    Agree on the race truck makes noise. :D I did tighten everything and still no go but gonna bing it to firestone to alignment again and see what happens.
  4. Mar 16, 2011 at 9:09 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Well that's not good.
    Have you checked your blinker fluid level lately?
  5. Mar 16, 2011 at 9:30 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i should do that to my truck. i'm sure my blinker fluid could use a new filter and a flush
  6. Mar 16, 2011 at 12:22 PM
    FixedTRD
    Will
    Alhambra, CA
    That was the first thing I did add more blinker fluid.
  7. Mar 16, 2011 at 1:54 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    then you good to go..lol
    did you check the uni-balls for play? get your CO's re-pressurized and get the alignement, but i', willing to be it's just the bushings being loud and obnoctious
  8. Mar 16, 2011 at 2:16 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Hmmm I always send it to a stealership to have them check blinker fluid. Is there a write up on it here somewhere so I could start servicing it myself?
  9. Mar 27, 2011 at 10:00 PM
    FixedTRD
    Will
    Alhambra, CA
    I got the truck align 2 weeks ago and everything was fine no more knocking, until this weekend when I took it to Vegas and hit some dirt trails now I have the knock again. I am still wondering what it is so maybe I can just re tighten it or something. Alignment is fine just knocks. Might being it back to get it align again.
  10. Mar 28, 2011 at 7:44 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    you can count on your alignment going out everytime you hit the dirt...
  11. Mar 28, 2011 at 2:40 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    alignment is over rated
  12. Mar 29, 2011 at 8:30 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Mine is kinda doing the same thing. Its kinda like the sound metal makes when its stressed. Just a light pop. I think its just the start of a baby squeak :D
  13. Mar 29, 2011 at 10:43 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    it's prob your steering rack... it's normal. 1st gens are notorious for making a "poping" noise... mine does it too.
