knocking,rapping and ticking
Discussion in '4 Cylinder' started by merlin3, Sep 7, 2013.
  1. Sep 7, 2013 at 2:04 AM
    merlin3
    merlin3 [OP] New Member
    2012 tacoma
    i have a 2012 tacoma with a 2.7. after it sits for a few hours when i start it and drive a few miles it makes a ticking,knocking and rapping noise coming from the motor.this happens in hot or cold weather,i just don't see this motor lasting a long time like i wanted.has anybody had the same problem?
  2. Sep 7, 2013 at 8:25 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I also have a 2012 2.7. That sounds serious. Had you considered taking it in under warranty for at least a diagnosis? Can you record the sound it makes? I accidently broke the plastic end plug off of my camshaft position actuator, and when I started up the engine, it made a rhythmic tapping sound, so I immediately shut it off and didn't run it again until I replaced the part.
  3. Sep 7, 2013 at 3:54 PM
    merlin3
    2012 tacoma
    after a few e-mails to toyota they finally said it was the pistons slapping against the cylinder walls,nice huh.problem is i live on a island and would have to leave it at the dealer when the rep showed up and it does not make the noise all the time.i did call the dealer and the service rep. said a lot of the 4 cylinders make noise and it is normal.i am not buying that,the old ranger i traded in sounded better than my new tacoma.i am stuck with junk.
  4. Sep 7, 2013 at 5:41 PM
    tooter
    Greg
    Los Angeles
    Was this a brand new vehicle? How many miles on it?
  5. Sep 8, 2013 at 5:32 AM
    merlin3
    2012 tacoma
    i have had this problem since new now it has 8400 miles and still making the noise.
  6. Sep 8, 2013 at 7:50 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Many tacomas do that, both 4cyl and v6; it's the hypereutectic pistons they use. They shrink more than the typical cast aluminum piston when they cool so the clearances have to be wider. Sounds like a diesel when cold, but overall a stronger part. My last truck was annoyingly loud for the first 2 minutes after a cold start.
  7. Sep 8, 2013 at 8:24 AM
    tooter
    Greg
    Los Angeles
    Thanks for that useful information, iroh. I had no idea that symptom even existed as my engine is silent even on cold starts.
  8. Sep 9, 2013 at 7:52 AM
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    Chevy LS motors have been doing it for a several years now. Both my 2002 and 2007 Silverado's had piston slap when cold. It's not just the material they use for the pistons that causes the cold noise condition, they have also reduced the length and size of the piston skirts, which reduces friction, but increases noise because the piston is freer to move around in the cylinder when clearances are greater.
    I haven't heard it so far in my 2012 2.7.
  9. Sep 9, 2013 at 8:20 AM
    tooter
    Greg
    Los Angeles
    You know for sure what piston slap is if you have a single cylinder motorcycle! :laugh:
