Knocking sound coming from front left
Discussion in 'Suspension' started by dziner, Jan 18, 2018.
  1. Jan 18, 2018 at 5:17 AM
    dziner
    dziner [OP] Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    I noticed this sound start yesterday while driving on some snow covered roads. Roads are clear today but I still hear it. I've got Bilstein 5100's with OME 885 springs and JBA UCA, and front driver side spacer for taco lean. This was all installed a little over a year ago.
    When I hit small bumps I'm hearing a clunking sound. It almost feels like something is bottoming out on the front driver side. Everything feels fine at highway speeds. I looked at things when I got to work this morning and can't visually see anything that would be causing this.
    Any suggestions as to what could be going on?
  2. Jan 18, 2018 at 5:19 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Do you have snow and ice packed up in the suspension?
  3. Jan 18, 2018 at 5:20 AM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Sway bar link?
    WRDD Taco and DustStorm4x4 like this.
  4. Jan 18, 2018 at 5:22 AM
    dziner
    Jonathan
    Nope, all is clear... just dirty and salty AF.
    Manfred likes this.
  5. Jan 18, 2018 at 5:23 AM
    dziner
    Jonathan
    Hmmm.... Might I need to get under the truck to check that? And would it be a visual inspection or do I need to take something apart?
  6. Jan 18, 2018 at 5:26 AM
    high n mighty
    Oshawa Ontario
    01 camo taco
    you will have to get under, most times it will show up if you grap hold of the sway bar close to the link and apply rapid up and down force on it, kinda like a forceful wiggle. it may not show up when its on the ground, you might have to get both wheels off the ground
    dziner[OP] likes this.
  7. Jan 18, 2018 at 5:28 AM
    dziner
    Jonathan
    Gotcha. Thanks for the info! I'll see if I can find a way to do this after work.
    Manfred likes this.
  8. Jan 18, 2018 at 5:29 AM
    dziner
    Jonathan
    If it is the sway bar, what needs fixed/replaced?
  9. Jan 18, 2018 at 5:29 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Following.
    I have a similar noise as well. 'Feel' it under my left foot when resting on the dead pedal.
    No sway bar. Took that junk off a while ago.
    My visual inspections are the same, OP. Just iced, slushed, and salted.
  10. Jan 18, 2018 at 5:35 AM
    memario1214
    Colton
    Missoula, MT
    Should just be the bushings if that is what is clunking around. Not a hard fix at all.
    I asked about the packed in snow and ice because I figured it was just a Tacoma thing... I have immediate access to 3 second gens (mine, sister's, and cousin's) all of which have clunking noise if they have impacted snow and ice in the wheel well or suspension area.
    dziner[QUOTED][OP] likes this.
  11. Jan 18, 2018 at 5:40 AM
    high n mighty
    Oshawa Ontario
    01 camo taco
    If it is the sway bar you will either have to replace the sway bar link that's attached to the very end of the bar or the bushings that hold the bar to the frame more towards the middle
  12. Jan 18, 2018 at 5:48 AM
    dziner
    Jonathan
    I may need to do a better visual inside the wheel area. We're getting a warm up tomorrow which should melt everything.
    Manfred and dirty deeds like this.
  13. Jan 18, 2018 at 5:55 AM
    dirty deeds
    Nick
    Eastern KY
    It'll start a :crapstorm: for saying this:
    Take off the sway bar if you wheel, man. Best decision I ever made!
    I'm a 4 banger, so the 885 are so damn stiff, the truck barely rolls unless I drive like I have somewhere to be.
  14. Jan 18, 2018 at 5:57 AM
    dziner
    Jonathan
    I get that. But, if I am ever in an accident and it's discovered that I do not have a sway bar, I'm liable for removing that safety/control piece.
    Manfred likes this.
  15. Jan 18, 2018 at 5:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It could be a loose end link, which may not be obvious just by looking at it. All you need is a 17mm to tighten it back up
    Like previously mentioned, the end links or the bushings, both of which are cheap. If the bushings, I have some I can mail you. I have two sway bars chilling in my shed.
  16. Jan 18, 2018 at 6:17 AM
    dziner
    Jonathan
    Sweet! Thanks man. I'll inspect and let you know if I need to replace anything.
  17. Jan 18, 2018 at 6:28 AM
    memario1214
    Colton
    Missoula, MT
    What a guy huh? @EatSleepTacos
    It's amazing this place... Post up an issue you are experiencing and you have an answer (or at least somewhere to start) before 0800 MT and someone offering up parts. Normal car forums you post up a request and you're lucky if it ever gets answered, let alone in a timely manner as car issues generally are rather stressful. Even if I were to move away from the Tacoma as my personal vehicle I am pretty sure this would still be home base as it is for many others (I see you mods)
  18. Jan 18, 2018 at 6:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :amen: When I sold my previous tacoma, I wasn't sure if I was going to be getting back into one, yet I still was on TW every single day. It's a great place to hang out and offer advice, among other things! I'm very happy I was able to get back into one and continue the trend.
  19. Jan 18, 2018 at 6:31 AM
    dziner
    Jonathan
    Definitely! Much love to TacomaWorld as a community.
    dirty deeds likes this.
  20. Jan 18, 2018 at 8:05 PM
    joeybags
    joeybags Well-Known Member
    joe
    pa
    2011 4x4 trd sport mgm
    i have a similaiar sound the other day made a turn into a parking lot heard a clunk or knock from my driver side, all other times it drives fine i have old man emu with 886 and dakars in rear with armor all around im gonna check tomorrow.
    Manfred and dziner[OP] like this.
