Knocking sound coming from somewhere at about 1000 rpm.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lthompson, Nov 4, 2019.
  1. Nov 4, 2019 at 2:18 PM
    Lthompson
    Lthompson [OP] Well-Known Member
    This has been going on for a few months and seems to be getting worse. Has anyone ever had knocking sounds coming from a catalytic converter? Seems like that is where it’s coming from but I don’t know.
  2. Nov 4, 2019 at 2:20 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    By chance do you notice it more when it's cold out? I have a very similar issue I'm having a hard time diagnosing, though I notice it the most when it is 60° F or cooler.
  3. Nov 4, 2019 at 2:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Which catalytic converters? the ones in the headers near the motor, or the secondary set in the ypipe? Seriously hope its just a cat that's bad and rattling and not something else. Any drivability issues or Check engine lights?
    whatstcp likes this.
  4. Nov 4, 2019 at 2:35 PM
    Lthompson
    Secondary/rear . No engine lights. I’m trying to upload a video but it’s refusing to work
  5. Nov 4, 2019 at 2:37 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Sound is coming from the transmission. Most likely the flywheel. It's been documented around here about them cracking and causing a uneven 'tick'. One way to check is put a scope in there and look for cracks
    Lthompson[OP] likes this.
  6. Nov 4, 2019 at 2:49 PM
    Lthompson
  7. Nov 4, 2019 at 5:30 PM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    what's the truck info
  8. Nov 4, 2019 at 6:55 PM
    Lthompson
    2011 v6 4door 4x4
  9. Nov 4, 2019 at 9:25 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Can't say for sure based on the vid...but it certainly varies with rpm, so it's definitely a rotating part that is making the noise.
  10. Nov 6, 2019 at 4:41 PM
    Lthompson
    Makes sense,, But, When you get under the truck, you hear it right at the Cat.. Like the engine pulses causing it.. I have seen some youtube videos of this.. But, like you said, its sounds like a rotating part issue.. But when I cant actually identify it as coming from the motor anywhere, it confuses me.
  11. Nov 7, 2019 at 2:02 AM
    12taco12
    rochester NY
    2012 TX Pro
    take it to a shop if you cant determine the source
  12. Nov 7, 2019 at 2:42 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    just curious, is the sound is any different right after start up versus after everything is up to temp from driving around?
  13. Nov 7, 2019 at 10:38 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    My '14/V6/MT6 does the same thing, has been doing it for the last 36k miles.
    It got really loud last year during deer season, so when it got too hot to hunt mid-day, I took the DS cat cover off and found a small rock wedged between the cover and the cat.
    That made it less noisy, but the noise is still there. From listening with a screwriver pressed to the cat, downpipe, bell housing, block, and a few other spots, it sounds loudest from the bell housing/lower block (just above the oil pan).
    UOA's from Blackstone are fine, so I suspect it's something in the flywheel/TO/pilot/transmission area (bell housing probably acts to amplify the noise). Annoying AF, but doesn't seem to indicate an internal engine issue if the UOA's are a reliable metric for that.
    Oh, yeah, and I plugged a fat forked horn later that evening, so double-bonus! ;)
    Kolter45 likes this.
  14. Nov 7, 2019 at 11:00 AM
    TACOGUY23
    TACOGUY23 Well-Known Member
    nj, usa
    2013 TACOMA SR5 4 DOOR
    mines same way... many from this site have same sound...very "normal" and goes away after a few minutes of warming up.i thought it was piston slap but many from here have reassured me its normal.
  15. Nov 7, 2019 at 11:02 AM
    TACOGUY23
    nj, usa
    google.... 2013 tacoma loud motor cold tacomaworld....
    Kolter45 and FrostbitTaco like this.
  16. Nov 8, 2019 at 10:57 AM
    FrostbitTaco
    FrostbitTaco Well-Known Member
    Toledo, Oh
    2015 Tacoma AC TRD Off road
    My 2015 sounds the same in the mornings during the cold starts. Once its warms up sounds dies down. There have been many posts on hear about the issues. Many have different appoints but majority I have read says "Normal". A few have even taken them in and all the mechanics say normal.
  17. Nov 8, 2019 at 12:30 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Check to make sure all of your heat shields are tight.
  18. Nov 8, 2019 at 2:46 PM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    crackils[QUOTED] likes this.
  19. Nov 8, 2019 at 5:22 PM
    Lthompson
    doesn't change once warm.. hard to notice on cold startup because of the engine idling higher.. Not affected by weather. Tried the screwdriver to the ear thing several times.. I can never hear anything on the motor or bellhousing indicating its from there.. But, its also quite hard to rev the motor while im underneath it.. lol
  20. Dec 13, 2019 at 4:52 PM
    ttc
    ttc Well-Known Member
    2013 Double Cab
    You figure it out? Mine is similar.
