Knocking sound when accelerating or stopping in a 2012 Tacoma
Discussion in 'New Members' started by Alexisbrito6, Jun 17, 2025.
  1. Jun 17, 2025 at 12:37 PM
    Alexisbrito6
    Alexisbrito6 [OP] New Member
    Henry Brito
    Tacoma 2012 Double cab 6 lug 4x4
    Suspension modified to 2.5 inches Procomp shocks and modified stock leaf springs
    I have a situation, I bought my second-hand truck, it had a knocking sound that was reflected in a wobble of the differential, but this only occurs when braking completely and when starting, a few modifications were made to the leaf spring to try to solve the problem, it was possible to reduce it by also adding a more rigid bearing, however the knock continues, it is worth noting that if it is cold the truck does not make the noise and if I am driving and put it in neutral it does not make the noise either.
