Knocking Sound When Idling in Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saskabush, Mar 25, 2017.
  1. Mar 25, 2017 at 7:42 AM
    Saskabush
    Saskabush [OP] Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    So for about a year now I've been hearing a knocking sound while in drive but stopped at a light or stop sign. It seems to happen about once per revolution and will speed up when I start to accelerate but will get quieter until about 2000 RPM and then can't be heard. If I put it into neutral the noise basically disappears or gets much quieter. It only seems to happen after the truck has been running for about 5 mins then goes away after about 5-10 mins or once the engine is fully warmed. The outside temperature doesn't seem to have much affect on it other than making it take longer to go away.
    I can hear it best from inside the cab and under the dash. I've tried listening under the hood while its happening but couldn't hear it over the engine noise.
    I've had my local stealership "take a look" but they figured it was a wire from my HID's rattling around lol. Obviously that is not the cause. I originally thought piston slap but shouldn't that go away once the engine starts warming up? Rather than START happening once the engine warms up a bit.
    2013 TRD Sport with 50k KM. Factory drivetrain. 4.0 V6 auto.
    Update March 30: Just had the noise happen again. Quickly popped the hood and removed the intake tube. Can confirm this is NOT the cause of the sound. It sounds like it's coming from the engine itself. But can not be heard from the engine bay over the other engine sounds. Which makes me think it is internal and the vibrations are carrying into the cab. I originally thought piston slap but it sometimes happens well after the engine is warm like in the video...
    Here's a video. https://youtu.be/uFJx75kTmEw
  2. Mar 25, 2017 at 8:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not regular enough to be engine. The sound has differing ocsillations.
    Trans fluid low? Once it expands from temp rise makes the sound go away?
  3. Mar 25, 2017 at 10:12 AM
    Saskabush
    Adam
    2013 TRD Sport
    Hard to say... Could be possible. It drives and shifts perfectly fine even when making this sound. I've never checked the fluid level but after reading about what checking entails, I may just be leaving it that way lol. I still have warranty but if I tell the crooks at my local dealership to check and that isn't the problem I get charged $135/hour shop time. I'm trying to see if there is any way of narrowing it down before hand.
    14TacoSC likes this.
  4. Mar 25, 2017 at 12:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would have that level checked. There was a rash of Tacomas from '09 to 15' that were under filled. At least for peace of mind.
    Soul Surfer likes this.
  5. Mar 25, 2017 at 5:23 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
  6. Mar 27, 2017 at 5:43 PM
    Saskabush
    Adam
    2013 TRD Sport
    That does sound similar for sure. But it must be something different on mine. That foam gasket is in excellent condition still and has lots of play left. I just check that this weekend to make sure. Thanks tho!
  7. Mar 27, 2017 at 5:52 PM
    Saskabush
    Adam
    2013 TRD Sport
    Update: This weekend I took a good luck at everything I could. All motor/tranny mounts look new still, intake tube gasket looks perfectly fine, doesn't seem to be anything that could be rattling or vibrating on the exterior of the engine.
    Still searching... Any feedback or suggestions are appreciated!
  8. Mar 27, 2017 at 5:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Inspect the sound from the exterior as it is doing it. That will be the only wah you could find it. As far as guessing goes, for us on the net, it's a toss up. It could be ANYTHING. It definitely is not going to be the engine though, that's what I can tell you.
  9. Mar 27, 2017 at 6:08 PM
    GreenGiraffe
    GreenGiraffe Member
    2006 Prerunner
    I had a knocking under my hood yet the truck runs excellent. Couldn't figure out what it was for the longest time. The problem ended up being the casing around my cold air intake. The weld had broken and the air filter was rattling against the housing of the air filter.
    Rewelded the piece; rattle is absent.
    Worth looking at if you have something similar under your hood.
    Cheers,
    -P
  10. Mar 27, 2017 at 6:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah you are going to have to get out and inspect it when its doing it. (have someone you trust hold the breaks with it in gear for you as that sounds like when its doing it)
    Maybe a heat shield on the exhaust?
  11. Mar 27, 2017 at 6:48 PM
    Armkb
    09 TRD Sport DCLB
    The gasket on my intake tube looked fine also but was the source of my problem. Could not tell where or what was making contact. Also could not hear the noise in engine bay or outside vehicle. Could only hear it from the driver seat... down low by pedals.
    Disconnect the tube from the intake and take it for a ride and see if noise goes away. Im almost positive its what your problem is. I chased this problem for years and couldnt believe it myself when I finally found the source as suggested here on TW.
    wilcam47 likes this.
  12. Mar 28, 2017 at 1:57 PM
    Saskabush
    Adam
    2013 TRD Sport
    That is pretty much exactly what is happening to mine. There was one time I tried popping the hood while it was happening and had a listen (had to put the e-brake on and leave it in gear :fingerscrossed:) but I couldn't hear it at all from the engine bay.
    My problem is intermittent so removing the tube won't really tell me anything unless I leave it off for like a month. I wish it would happen every time! It would be way easier to diagnose. Next time I hear it I'll try to play around with that tube though and see if it helps. That would be great if this was the problem!
  13. Mar 28, 2017 at 1:59 PM
    Saskabush
    Adam
    2013 TRD Sport
    I have tried to get out and see if I can hear it from under the hood. No luck unfortunately. I had to just put the e-brake on and leave it in gear. Whatever it is is completely masked by the other engine sounds. I also checked the heat shields this weekend and they don't rattle at all. It doesn't really sound like a rattle at all actually. It sounds like someone is tapping their knuckle on my firewall.
  14. Mar 28, 2017 at 3:01 PM
    Armkb
    09 TRD Sport DCLB
    Saskabush...Ive tried more than once to convince you to just take the damm thing off for a while and see if its the source of your problem. Only takes 3 minutes tops. My last post on this subject.
  15. Mar 28, 2017 at 3:18 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Loose baffle in the cat ?
  16. Mar 28, 2017 at 5:17 PM
    Saskabush
    Adam
    2013 TRD Sport
    Removing it right now tells me nothing. I'd rather it make the noise so I can verify what it is than start removing things and never know what is actually causing it. I'm going to leave it alone until I hear the noise again and that will be the first thing I check to see if that is the cause or not. It's easy enough to check on the fly. I carry tools in my truck and can quickly remove it if need be once I hear the noise again. That cool with you??
  17. Mar 28, 2017 at 5:39 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    had this problem with mine. it was the intake tube on the inner fender. when I put on my trd intake noise went away.
    Armkb likes this.
  18. Mar 30, 2017 at 11:34 AM
    Saskabush
    Adam
    2013 TRD Sport
    Just had the noise happen and quickly removed the intake tube... Didn't make a difference unfortunately. I was really hoping this was the cause because it's a lot easier to fix than something internal! Thanks for the suggestions.
  19. Mar 30, 2017 at 2:57 PM
    Armkb
    09 TRD Sport DCLB
    Damm...I hate being wrong. Hope you get it figured out!
  20. Mar 30, 2018 at 8:15 AM
    TomHouse
    TomHouse Well-Known Member
    San Francisco
    2016 Subaru Outback 2.5 Premium
    (former prerunner owner)
    You ever figure this out? My 2012 doing same thing exactly.
