Knocking when cold
Discussion in 'Technical Chat' started by Triangleacre1, May 10, 2012.
  1. May 10, 2012 at 12:19 PM
    Triangleacre1
    Triangleacre1 [OP] Well-Known Member
    Dustin
    Delaware
    01 Tacoma SR5
    I got an 01 2.7L. When I start it up and accelerate at first when it is cold I hear what sounds like a knkocking noise in the front somewhere. Do you know what it might be?
  2. May 11, 2012 at 8:45 AM
    Triangleacre1
    Dustin
    Delaware
    01 Tacoma SR5
    Anyone know what it may be?
  3. May 11, 2012 at 8:46 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Valves?
  4. May 11, 2012 at 8:47 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    what oil are you using? could be too thick.
  5. May 11, 2012 at 9:59 AM
    Triangleacre1
    Dustin
    Delaware
    01 Tacoma SR5
    I used the 5w-30 I think it was Pennsoil. Its due for a change in about 1,100 miles.
  6. May 11, 2012 at 10:12 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    hmm weird, that oil is fine.
    so it's a knocking sound, not a ticking. I would hope it's not the rod bearings or something like that.
  7. May 11, 2012 at 10:14 AM
    babytruck
    NorCal
    Please correct me if I'm wrong....The valves would knock if the oil cannot get through due to bent cyls?
  8. May 11, 2012 at 10:23 AM
    Triangleacre1
    Dustin
    Delaware
    01 Tacoma SR5
    It hasnt always done it. But it only seems to be when its cold. If I start it a few minutes before i drive or after I get about a mile down the road I do not hear it.
  9. May 11, 2012 at 10:43 AM
    babytruck
    NorCal
    When the engine warms the cyls expand, allowing passage.
    Hopefully I'm wrong with what I'm saying. It happened to one of my vehicles and for me it was either pay big bucks to fix it or get rid of the vehicle.
  10. May 11, 2012 at 10:46 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    knocking almost always means low oil pressure or worn rod bearings (the bearings between the connecting rods and the crank shaft). I suggest starting the truck about 30 seconds or more before setting off to allow the oil pressure to come up.
  11. May 11, 2012 at 10:46 AM
    babytruck
    NorCal
    If you can, take a LONG screw driver - the longest one you can find or borrow - , and with the engine on, put the metal end of the screw driver near each of the valves. Put your ear on the handle part. The sound will travel up the metal and you should be able to hear where exactly the sound is coming from.
  12. May 11, 2012 at 6:22 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
  13. May 21, 2012 at 5:55 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    Most likely is piston slap. Piston slap that goes away within a couple of minutes as the engine warms up isn't usually harmful, and is not a reason to tear down an engine. I had a '76 Chevy with piston slap. It slapped for 22 years, and was never problematic. I also had a '93 Toyota with a 22RE engine that slapped when cold. No problems from that one either.
