Knot on my spindle near my tire...need input asap!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corywayne, May 29, 2015.
  1. May 29, 2015 at 7:32 PM
    corywayne
    corywayne [OP] Member
    cory
    2012 toyota tacoma TRD
    king 2.5 front coilovers 2.5 rear ,total choas UCA
    So in installed my front king suspension and there's a knot on my spindle about a quarter of an inch away from my tires when I put my 33's on there will it rub ????
  2. May 29, 2015 at 7:33 PM
    corywayne
    cory
  3. May 29, 2015 at 7:34 PM
    corywayne
    cory
  4. May 29, 2015 at 7:37 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    What offset do you have on your rims?
  5. May 29, 2015 at 7:49 PM
    corywayne
    cory
    My new rims have a 4 in off set with a 285/75/r16 MT
  6. Jun 1, 2015 at 7:59 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Best bet would be to run wheel spacers.
    4.5 BS is the most ideal for bigger tires and a lift
  7. Jun 1, 2015 at 8:05 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    What the hell? I haven't seen this one before. I have spindles here for a 2010 and a 2013 and none of them have that.
  8. Jun 1, 2015 at 9:19 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    You have that backwards. If he has 4" BS, 3.5" would move the wheel further out away from the spindle.
  9. Jun 2, 2015 at 12:20 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Should not be a problem, until you air down. I'm not sure of the purpose of the marks; you can try grinding them down or getting spacers. The thinnest I've see are .9 inches wide.
  10. Jun 2, 2015 at 3:57 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    those are power zits....makes the arm stronger
  11. Jun 2, 2015 at 8:08 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I'd blend that down and not look back.
  12. Jun 2, 2015 at 10:43 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Maybe it's a 2012 thing I just can't imagine them only doing it those years. I'm gonna check mine again
  13. Jun 2, 2015 at 3:52 PM
    corywayne
    cory
    My scs rims with my 285/75/r16 MT's cleared that knot a hell of a lot more
  14. Jun 2, 2015 at 3:57 PM
    Lipson
    Lipson Well-Known Member
    Adam
    San Diego
    '97 T4R Limited
    When I first put my lift on and bigger tires using the stock rims I had this problem. The spindle "knob" touched my tire. I took a grinder to the knob and ground it down flat. Do this or get wheel spacers
  15. Jun 2, 2015 at 5:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    That knot is probably part of the casting process.... take a grinder to it if you are worried about clearance.
  16. Jun 2, 2015 at 6:36 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    umm, no it isn't 'part of the casting process' it is an intentional design to strengthen it
    casting has been done since 600bc, it's pretty much well thought out by now.
    scocar likes this.
  17. Jun 2, 2015 at 6:42 PM
    jmaack
    Justin
    Helena Alabama
    They wouldn't have a sharp edge to strengthen a casting. It will cause a stress riser.
    Google sharp edge on castings.
  18. Jun 2, 2015 at 6:49 PM
    jmaack
    Justin
    Helena Alabama
    Edit. I think I was looking at the bracket close to the lip of the rim...
    Still the other bump highly doubtful is strengthing.
  19. Jun 3, 2015 at 6:02 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    ^^unless you can prove otherwise I stand by what I said. 100% intentional with careful engineering thought.
    probably vibration and harmonics related, maybe if hub fails it causes tire to scrub and make a safer stop
    who really knows and who really cares? but mistake or oversight, no.
    BUZZCUT likes this.
  20. Jun 3, 2015 at 10:50 AM
    OrangeTexan
    OrangeTexan Well-Known Member
    San Antonio
    2012 4X4 TRD OR
    Its not for strength nor harmonics. The shape of it doesnt make sense for either case. I personally think it is a tire width indicator. If you try to put too wide of a tire on the stock rim and it contacts this nub this tells you that the tire will rub somewhere.
