Knowing when to replace shocks
Discussion in 'Suspension' started by Chickenmunga, Mar 16, 2011.
  1. Mar 16, 2011 at 12:13 AM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    It may seem like a no-brainer for some of you, but I never knew how to look for worn out shocks beyond the 'bounce test' or general feel. Hopefully this helps some of you guys too.
    How to tell if shocks are worn out
    Scroll down to the pictures.
  2. Mar 16, 2011 at 12:23 AM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    McKinleyville, CA
    2015 Black Tacoma AC TRD 6MT V6
    Typically, oil loss is a good sign. Or do the bounce test. Use your whole weight and bounce each corner of your vehicle. It should only bounce 1-1.5 times. Anything more is excessive.
  3. Mar 16, 2011 at 10:13 AM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I found out by the oil that wasn't supposed to be there...think I'll read your link.
  4. Mar 16, 2011 at 10:22 AM
    drifter
    Sam
    Oregon
    good stuff
    I would probably be one of those people with tire seizures...haven't replaced the shocks yet.
  5. Mar 16, 2011 at 12:58 PM
    jst3751
    jst3751 Member
    Southern California
    08 PreRunner DBL Cab
    Shell, Rear Axle Aire Lift kit, Inverter, Dual battery kit.
    I know there are a lot of variables involved, but aprox how long should stock shocks on an 08 (non-TRD) last? I have 46K miles and it seems like the front end is getting a little loose/bouncy on our "wonderful" Southern California Freeways.
