Known problems with 2022 Tacomas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SMCTaco, Jun 11, 2024.
  1. Jun 12, 2024 at 5:05 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    I second the steering rack, mine started seeping right around the 60k mark go figure.
  2. Jun 12, 2024 at 5:11 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It must suck to be some of you guys! My advice to OP; buy it, drive it, and be happy. Shit might happen, but then again it probably won't.
    Dark_Taco, RIX TUX, Junkhead and 3 others like this.
  3. Jun 12, 2024 at 6:04 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    The problem I have is I paid what I consider a premium price and then my new Tacoma was on a sixty day quality control hold and then when it finally arrived I almost refused to take it. Although all issues were resolved at Toyota’s expense it should have never been shipped.
    Even with all the issues as I have stated I still love the truck.
    I really just want other owners to see these issues and have Toyota repair them while under warranty and hopefully get back to building the quality Toyota has been known for in the past.
  4. Jun 12, 2024 at 6:11 AM
    mwb
    mwb Well-Known Member
    I've got a 2022 SR 2.7 that I bought new. After 2.5 years, and 35,000 miles, I've had zero issues with it.
    1fatmac, bodydenny and CT-Tacoma like this.
  5. Jun 12, 2024 at 6:16 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    That’s just the thing some owners never experience the typical problems and others do maybe it depends on what day of the week the truck was built.
    So far I have not had any of the typical mechanical problems just panel alignment that Toyota corrected.
  6. Jun 12, 2024 at 6:24 AM
    SMCTaco
    SMCTaco [OP] Member
    Taco
    I am the OP. What I meant by known common problems is illustrated by my problems with my 2007 Rav4 with V-6. 2007 was the second year of that Rav4 generation. My Rav4 had an external oil line made partly of stainless steel and partly of rubber. Toyota sourced the wrong rubber for the oil line, and the oil lines began failing. Toyota issued a secret directive to replace the rubber section when one came in for other work. Mine was never fixed before I bought it, and it failed on a vacation trip. There were numerous defective water pumps, and a problem with the valve train that required replacing the entire valve train. These problems were common to all 2007 Rav4s with the V-6 engine. Toyota replaced the rubber and stainless oil line with an all-stainless line in 2008. I think they also fixed the valve train and water pump issues in 2008. Are there any problems common to most or all 2022 Tacomas or certain components of 2022 Tacomas?
    BillF1564 likes this.
  7. Jun 12, 2024 at 6:38 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, go back and read all the post made on your thread. I think you will find the answers you are looking for.
    Chew likes this.
  8. Jun 12, 2024 at 6:44 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This>
    From my initial read on this board, it appeared that Tacomas were expected to be constantly granading around you as you drove down American roads...
    Tacos are as reliable as it gets these days. And that is pretty good.
  9. Jun 12, 2024 at 7:02 AM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    The only reason that we have a list of issues like that related to the Tacoma despite it's reliability and rock solid nature is because the Tacoma community is so involved and so in love with this truck (despite its obvious flaws) that everything is documented and noted. You can come on this forum and ask almost any question about the Taco and someone will know the answer. There are not many other communities devoted to cars/trucks with this level of knowledge about the vehicle except maybe Jeep.
  10. Jun 12, 2024 at 7:11 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    This is a great place to get lists of anecdotal issues (and helpful solutions) that are statistically unlikely, yet frequently used for trolling.
    You’re better off consulting statistic-based resources like car-complaints & consumer reports, which will confirm what the vast majority of 2mil or so Gen3 owners already know, that the trucks themselves are relatively bulletproof.
    A 2022 Tacoma is pretty much as good as it gets, just beware of the trolls.
  11. Jun 12, 2024 at 7:11 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The 2022 was “supposed” to be the last of the third gens, but COVID delayed Gen 4 until 2024.
    Essentially that means the 22 & 23 models are nearly identical, and were the ones that had all the bugs worked out, and some nice features added. (Acoustic glass, power seats, better tune….)
    I think you’ll find that it should be a very good choice.
  12. Jun 12, 2024 at 7:26 AM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    I’m the guy in love with my two 22's:
    I had a 2017 sr5 taco that totally sucked (mechanically and design), especially after driving the 2015 sr5 taco. But it never left me stranded.
    Op, if the 22 you’re interested in has a clean history buy the truck.
    gr8-wrx and t0p_d0g like this.
  13. Jun 12, 2024 at 7:32 AM
    SMCTaco
    SMCTaco [OP] Member
    Taco
    SlippRott, the Rav4 forum is full of info as well. That is how I discovered the issues that were common to 2007 Rav4s with the V-6 engine. Good user forums (fora for you Latin scholars) are the best resources for prospective purchasers. I paid a Toyota dealer $100 for a pre-purchase inspection of my Rav4, and they didn't tell me about any of the common problems. The CarFax was clean, so I thought I was golden. I spent about $3,000.00 getting the 3 major common problems fixed. If I had researched the user forums, I probably would have passed on the vehicle.
    BillF1564 and Spacecoast like this.
  14. Jun 12, 2024 at 8:18 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    My 2023 tacoma sr5 v6 has what I thought was a “rough” idle in gear and some vibration from the floor board and gas pedal. Back to the dealer 6 times with no fix. Ended up test driving another used 2023 tacoma and it was the same as my truck. Guess they all have slightly different “personalities” some smoother than others. I’ll note that I did buy an oem Toyota steering wheel damper that bolts on behind the airbag, the damper is for another tsb issued for the Tacoma due to a vibration coming from the rear of the truck. The damper has made a dramatic difference in the frequency of the vibration through the gas pedal and floorboard. Big thumbs up!
  15. Jun 12, 2024 at 2:49 PM
    #35
    bodydenny
    bodydenny Active Member
    Dennis
    '22 SR
    none
    A friend of mine is a Jeep owner. I thought that was the only online group that obsessed about the vehicle. After buying my Tacoma,this board ( amount and depth of content) shocked me!
    BillF1564, StayinStock and Gfenza89 like this.
  16. Jun 12, 2024 at 4:08 PM
    #36
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    This is so much bullshit. You could run into a penguin this evening right? Chances are high you won't though.
    That describes this post.
    JmsWms, brigsby99, BillF1564 and 2 others like this.
  17. Jun 12, 2024 at 4:46 PM
    #37
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Not BS just facts do your research! Everything I have stated is fact you must surf the threads looking for someone to criticize! OP wanted to know known issues I spelled out just a few. I have never said that 3rd gen Tacoma was a bad truck if you would have bothered to read the entire thread you would have seen the positive post I have put up.
  18. Jun 12, 2024 at 5:06 PM
    #38
    OZ TRD
    Central Coast CA
    Yeah - but you could...
    It wouldn't happen if you owned a (insert other car brand / model here).
    I know a guy who knows a guy... and the penguin he ran into was massive!
  19. Jun 12, 2024 at 5:22 PM
    #39
    Tjbartle
    Tjbartle New Member
    2022 Tacoma TRD Off-road
    Stock
    27K on my ‘22 TRD OR. Besides the shitty gas milage and the seats get uncomfortable on long trips, love mine.
    t0p_d0g likes this.
  20. Jun 12, 2024 at 5:51 PM
    #40
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    FWIW my 18 had none of the issues mentioned above.
    Been a rock solid machine and I’m not easy on my truck at all.
    Just like with everything though, quality went down after scamdemic BS. Humans have also seemed to change, for the worst.
    RIX TUX and t0p_d0g[QUOTED] like this.
