Knuckle Gusset Exchange
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by zippsub9, Mar 30, 2024.
  1. Mar 5, 2025 at 2:20 PM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    How does the knuckle exchange work ? Buy a set and return the ones on my truck after they are installed ?
  2. Mar 5, 2025 at 2:22 PM
    zippsub9
    zippsub9 [OP] Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Absolutely. I add a core charge that is fully refundable once I get your OEM set back. There is no time limit for you to exchange the set out.
    baboltin[QUOTED] likes this.
  3. Mar 5, 2025 at 2:23 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    What is the cost ?
  4. Mar 5, 2025 at 2:30 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    PM sent. It fluctuates a little based upon steel cost and availability as well.
    baboltin likes this.
  5. Mar 12, 2025 at 5:18 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Two more sets rolling out. How do I know the OEM core exchanges aren’t bent? Great question. I place the machined surface on a certified flat granite slab to check the neck against a known OEM straight knuckle. Check out the second and third pictures below to tell the difference. Only a couple degrees of variance will show. Pics of the variance are from one my mentors that showed me what right looks like.
    RDT415 and hoodwinked like this.
  6. Apr 20, 2025 at 9:12 PM
    hoodwinked
    hoodwinked Well-Known Member
    These are going on the truck Tuesday! Thanks again!
    zippsub9[OP] likes this.
  7. Apr 22, 2025 at 10:22 AM
    Jes963
    Jes963 Well-Known Member
    Fontana CA
    2018 Tacoma Trd pro
    Post some pictures of the install would like to see how they come out
  8. Apr 30, 2025 at 1:06 PM
    hoodwinked
    Will do. They are installed. Very beefy. Two notes I have.
    First, there is no way these will fit any stock backspacing as advertised. I have 5.29" backspace and the clearance is razor thing, not even joking. It won't hit, but they are freakishly close. The most backspacing available on stock wheels is the 17x7.5 +30mm offset Sport wheels. This is 5.50" backspacing. Not an issue for me as I will only go less backspacing from here.
    Second, I had to add a sway bar drop kit to get it to work with my particular setup. YMMV.
    Otherwise great gussets. Super beefy and look great. I would say ideally no more than 5.00" backspacing for enough clearance for peace of mind.
  9. Apr 30, 2025 at 1:24 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Here are some on a 2017 TRD OR, the wheels are SCS. No issues on swaybar.
  10. Apr 30, 2025 at 1:26 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I don’t have any pics with stock wheels and no spacer. I am going to mock up a setup in my shop
    and take some measurements.
  11. Apr 30, 2025 at 1:46 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Here are the modeling and a mockup in the shop on a stock wheel.
    E82DED69-9304-4EC8-A235-A923D9647376.jpg 138622B7-906D-44C5-8F06-EF698348B0F6.jpg A0EB7693-9F4C-4B49-9258-302887CBE69A.jpg 5252E8EE-328B-456B-9373-125251258F1B.jpg D515A9DD-7EC1-4EFA-8AE5-BC399BBA42F6.jpg A5A3D389-D40D-4C85-9E73-D8533C2C0D9B.jpg
  12. Apr 30, 2025 at 3:13 PM
    hoodwinked
    Yup. Toight like a tiger. It does work, but man very little clearance. SCS wheels are generally more negative offset so clearance is all good. I'm telling you, no possible way these would fit on a stock 5.50" backspace....but again that is only on the Sport wheels. Every other stock config is good to go.
    TacoDell60 likes this.
  13. Apr 30, 2025 at 3:15 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    That is good feedback, thank you for that. Pretty familiar with 2nd gen stock wheels and the modeling was an OR IIRC. Get pics up when you get it all setup!
